synthetic vs. non-synthetic
Old Jul 7, 2006 | 01:24 PM
Derek173's Avatar
Originally Posted by rob40wilson03
i cant find info on GC on bobistheoilguy.com, did you learn about it in a forum there..... and why did it convince you to use GC?
GC has its own section in the forum . Yes I learned about it at bitog. Its a much thicker synthetic then Mobil -1..which the VQ35 likes. Many people also posted used oil anaylysis on that site and the results for GC in the VQ were great, very low wear.
Give it a try, its Castrol syntec 0w-30 and it says made in germany on the back of the bottle (the rest are made in USA). AutoZone is the only store that carries it according tho what I know.
Old Jul 7, 2006 | 01:29 PM
Derek173's Avatar
Originally Posted by jetblackg35
I run Mobil 1 every 3500 miles
you are wasting your money you can easily run it to 5k. I run mine untill 7.5k.
As long as you are running a good filter any synthetic will run 10k with no problems. Two of my friends are running mobile-1 extended performance. One of them runs it for 15k (which is whats its good for) the other changes out once a year 13-15k.
Old Jul 7, 2006 | 04:13 PM
UK-Nissan's Avatar
http://neptune.spacebears.com/cars/s.../oil-life.html
That will help.
Mike
Old Jul 8, 2006 | 12:47 PM
Q45tech's Avatar
Full synthetic oils have the molecules of the base oil all equal in chemical composition and diameter measured in DALTONS.
Old Jul 8, 2006 | 04:11 PM
UK-Nissan's Avatar
The benefits of a fully synthetic are not based on the length of the base stock.
It is the stability of the base-stock in an engine that matters, it needs a low viscosity, high boiling point, resistance to oxidation, stability under shear, and a few other characteristics.
Mike
seagrasser
May 3, 2022 09:43 AM
heynow
2nd Gen (V36) Sedan
Oct 28, 2015 05:09 PM
MrIP35
Oct 25, 2015 11:13 PM
celwin
V36 Engine, Exhaust, Drivetrain & FI
11
Sep 28, 2015 03:52 AM
bigmike
Sep 17, 2015 01:58 PM
