low rpms/stall like sound after mid pipe install
Old Jul 15, 2006 | 03:36 PM
driguez's Avatar
alright last tuesday i installed a coupe middy on my sedan and i have noticed since the install that when i stop at a light or with the car on P it idles way too low, it even sounds like is gonna stall, it has the kind of sound like when it needs new plugs but i just replaced them yesterday, it drops down to around 550rpms-600, it only does the stall thing when im at a light or something, not when the car is running, could it be a leak from the middy?? thats what im thinking but i wanted to ask bc i know theres a lot of knowledgable posters, thanx in advance
Old Jul 15, 2006 | 04:20 PM
cyphr's Avatar
I'm willing to bet that it's an exhaust leak. Check all your connections.
Old Jul 15, 2006 | 11:11 PM
driguez's Avatar
thanx, anybody else??
Old Jul 16, 2006 | 09:09 AM
godmans's Avatar
check your gaskets and connections too
did u re-use ur old gaskets?
Old Jul 16, 2006 | 10:27 AM
elrooko's Avatar
Wierd, I had sorta the same simptom when I installed my plenum spacer, ztube and K&N. It would idle way too low, and feel like it was about to stall. I followed the procedure for the "idle air volume reset" and it worked like a charm. Car consistantly went to 650 RPM at idle, even from a fast decelleration, or when revving it.
Old Jul 16, 2006 | 01:34 PM
driguez's Avatar
do you have a link for that reset??? thanx
:edit: nevermind, i think this is it https://g35driver.com/forums/faq-diy/6538-ecu-resets.html
Old Jul 17, 2006 | 09:36 PM
driguez's Avatar
so i wnt today to the muffler place and he said theres no leaks, what else could it be??
poktanG35
Engine - Exhaust
Oct 26, 2015 03:32 AM
johnjohn077
Engine - Exhaust
Oct 2, 2015 06:41 PM
Cam_Cooper3
Intake & Exhaust
Aug 10, 2015 07:04 PM
wuppiedog
Aug 7, 2015 11:16 AM
