What are the benefits or consequences of using a colder plug N/A?
Old Jul 24, 2006 | 10:47 AM
exagorazo's Avatar
What would be the result of using a plug one step colder than OEM in a N/A engine?
Would it result in excessive fouling of the plug?
Would there be any benefit?
Old Jul 24, 2006 | 12:30 PM
badtziscool's Avatar
No benefits whatsoever on an NA engine, and more than likely you'll foul the plugs faster.
Only use colder plugs if the combustion environment will be "hotter" as in under boost or extremely high compression. So the only time you really want to go colder on NA is if you increased the compression ratio of the engine.
Old Sep 25, 2006 | 04:21 AM
bythabay's Avatar
what about if you have engine pinging... will the colder plugs help then?
Old Sep 25, 2006 | 09:02 AM
rcdash's Avatar
i believe that's what the service manual calls for if there is pinging...
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
jeffbdye
Jun 1, 2018 03:51 PM
KallDay86
Jan 8, 2016 12:42 AM
BfloG35
Audio/Video/Electronics
Oct 16, 2015 05:22 PM
Patrick Bovee
Oct 1, 2015 10:42 AM
