Installed my Injen CAI and I'm Having Issues....NEED HELP
Old Jul 26, 2006 | 02:41 PM
G's Up's Avatar
Hey Guys and gals,
I installed my CAI the other day and everything went smooth, it was a pieace of cake.
But then as i turned on my car and started driving it around, i noticed a high pitched sound coming from my engine, upon further investigation i dtermined the sound was coming from the throttle body.
If the i hit the gas hard or even as im accellerating moderately i hear a high pitched squeeling sound coming from the throttle. Is this normal or not? The sound is kinda annoying and just doesn't sound right, almost like something is loose and/or not wokring right. the car drives fine and there are no check engine lights on, so i wanted to know if it was normal before i uninstall the whole thing and put the stock box back in.
Thanks for the help!
Old Jul 26, 2006 | 03:31 PM
superchargedg's Avatar
did you make sure the silicon hose is completely on the throttle body and tight.thats all i can think of,i had the injen for awhile and had no problems.
Old Jul 26, 2006 | 04:18 PM
sliderg35's Avatar
Squeeling is not "normal". Something is loose and letting air get in where it shouldn't. Re-check your installation.
Old Jul 26, 2006 | 04:37 PM
G's Up's Avatar
thanks for the help, but i double and triple checked the seals and the install, the noise only comes on at moderate to wide open throttle and the noise is coming from the throttle body, it does not sound like a leak in the seal.
so frustrated
Old Jul 26, 2006 | 04:48 PM
Back2VQ's Avatar
i used to own an s2000 which did the same thing when i installed my injen cai...i think it's normal, as long as everything's tight and nothing's leaking. any injen cai owners out there?
Old Jul 26, 2006 | 09:35 PM
Dan_K's Avatar
Is the squealing a whistling sound? Is it coming from the filter area? Does it come on only during certain rpms (ie. 3000-3500)? If so, its normal with any CAI. If not, retighten all the hoses. You have a leak somewhere.
Old Jul 26, 2006 | 09:42 PM
revreaction's Avatar
its normal..
it sounds normal to me..the squealing whistling sound comes from your intake arm diameter being larger than your throttle body diameter..it shouldn't be a problem..i think it sounds nice actually..
Old Jul 27, 2006 | 12:12 AM
Tweaksalot's Avatar
^^+1
Old Jul 27, 2006 | 12:42 PM
G's Up's Avatar
it's def not coming from the filter area, it's coming from the throttle body. it comes on when i stomp on the pedal or drive hard...i had the hood open and was able to determine where the sound was coming from.
it kinda sounds like a pressure valve being released when i hit the gas, but if i stay on it i hear the sqealing.
i guess i need to hear someone elses to determine if mine is normal
Thanks for all the input guys, really appreciate it
maybe i can try and get a sound bite to determine if its normal
Old Jul 27, 2006 | 12:44 PM
G's Up's Avatar
i feel like i can hear the throttle opening up if that make sense
Old Aug 1, 2006 | 06:28 AM
slidewaysg35's Avatar
hey i have an 03 g35 with the injen intake and mine makes a squeeling noise when im half way inthe throttle but when im idling or full throttle i dont get a squeel i also have checked all my hoses and they seem to be fine. i dont think you have a prob. because mine has driven excellent and no problems since the intake was installed about 5000 miles ago
Old Aug 2, 2006 | 10:47 AM
Pearl05G's Avatar
I have the same thing with the Stillen and Z tube. Although I didnt have it when I had the Injen. Sounds similiar to that of a turbo spooling...
Old Aug 2, 2006 | 11:24 AM
Zerk's Avatar
That doesn't sound at all normal to me. Sure WOT makes the engine louder but mine doesn't sound like that.
Old Aug 7, 2006 | 12:51 AM
sjc1789's Avatar
Florida G35 Club
Im with pearl05g.. i have an injen CAI... i get kind of a whistle sound right when i press the pedal hard, when i let of the gas, and when im jus cruising like round 3000k right before shift i hear it... its more of a light BOV sound than anything else in my ride... 05AT
Old Aug 8, 2006 | 07:42 AM
turbo spooling is the exact sound i hear in mine like around 3000 to 4000 rpm when im holding at a constant but when i punch it it goes away
