Pulley Set - 8-12 hp/10-14 ft lbs Torque
Old Oct 8, 2003 | 03:29 PM
Anonymous's Avatar
Anyone have these yet? Available at: www.hopupracing.com/unulss3puset.html
Ultra SS Lightened Underdrive Pulley Set
What is the result of evolution? Unorthodox Racing Ultra Street Sets build upon the success of Ultra Street crank pulleys by adding the Ultra Accessory pulleys. Each accessory pulley is made of lightweight 6061-T6 billet aluminum, lighter than the factory piece it replaces, and includes lightening holes where possible. Splines and bores are precision machined for accurate fitment which makes them an excellent replacement for the brittle plastic pulleys found on many late model cars. Premium fit and finish ensures a beautifully matched set you are proud to display under the hood of your vehicle.
Kit Includes
Crank Pulley
Alternator Pulley
Water Pump Pulley
HP & Torque: 8-12 hp/10-14 ft lbs Torque
Installation: Installation time for most applications is 2 to 3 hours.
Availability: Usually ships in 5-7 business days.
04100150Regular price: $399.00Sale price: $331.00
Anonymous's Avatar
Kit Includes
Crank Pulley
Alternator Pulley
Water Pump Pulley
Old Oct 8, 2003 | 03:43 PM
ducatiguy's Avatar
Premier Dough Slapper
Re: Pulley Set - 8-12 hp/10-14 ft lbs Torque
For the most part, underdrive pulleys are great! They do in fact produce extra ponies, are inexpensive, and take no time to install. I've had them on several vehicles and have always felt an improvement.... BUT!
One situation that I encountered, and something you may want to think about before getting a set....
I had a set on my M3 (prior supercharging the engine, and when my warranty was still in effect), and one day I my check engine light came on. When I took it in for service, they found out it was a bad O2 sensor and it was replaced. Nothing to do with the pulleys, but as I was leaving the service manager mentioned to me. If something were to happen to the engine, in specific the alternator, the crank, the water pump and just about any of the other accessories, the warranty on those item could be voided, due to the use of these aftermarket pulleys. When I told him they actualy underdrive em, so in theory the accessries will work less, he said regardless. The car was engineered with them on, thus anything that may happen, could and may be traced back to the pulleys.
So after hearing that, if I were to get these for my G, and if by chance my water pump goes on me, Infiniti could turn around say - hey you changed the pulley, we can't warranty that item.
Sure this all depends on the dealer and service center, but it's something to seriously think about!
Old Oct 8, 2003 | 03:45 PM
ducatiguy's Avatar
correction....
"he said regardless. The car was engineered WITHOUT them on, thus anything that may happen, could and may be traced back to the pulleys."
laksjd84
Steering & Suspension
16
Jul 12, 2017 12:22 AM
Machine Head
19 Inch
Mar 16, 2016 08:55 PM
SIKKI
Sep 16, 2015 01:14 AM
Machine Head
Sep 4, 2015 07:22 PM
Kicknshift
Sep 3, 2015 09:35 AM
