Question = Motordyne 5/16" spacer
Old Sep 7, 2006 | 09:52 PM
Jum's Avatar
Jum
Florida G35 Owner
I have a leased 06 sedan, im thinking about adding a Motordyne 5/16" spacer
hows the install with it? and is it easy to remove? Worth it? would be alright with my lease?
Thanks
Old Sep 7, 2006 | 09:56 PM
OhMyG...35's Avatar
It takes about 45 minutes. Its fairly simple they give you step by step directions. The only pain is having to torque the bolts. It comes off just as easy as putting it on. You should have no problems you can't even see it unless you are really looking.
Old Sep 7, 2006 | 10:00 PM
Andy2434's Avatar
The spacer itself is quite an easy installation. Prior to the install, be sure to be familiar with all of the steps. With regard to the upper plenum bolts . . . You will be using new bolts, which are included. Be sure to use an inch-lb. torque wrench. That will eliminate any quess work on your part.
Old Sep 7, 2006 | 10:01 PM
Jum's Avatar
Jum
Florida G35 Owner
is it easy to remove? and the 5'6 would allow me to keep the engine cover right?
Old Sep 7, 2006 | 10:08 PM
Andy2434's Avatar
Yes, the 5/16" spacer will allow you to retain the OEM engine cover. It is quite a simple task to remove the existing upper plenum. If you happen to have someone available, they could hold the upper plenum for you, while you install the spacer. I installed the spacer and the lower plenum/collector (MREV+) by myself. So, I removed the upper plenum/throttle body assembly to get it out of the way.
Old Sep 8, 2006 | 03:56 PM
Jum's Avatar
Jum
Florida G35 Owner
my cars auto, is it still worth to get
Old Sep 8, 2006 | 03:59 PM
abcquackyxyz's Avatar
the basic 5/16" spacer is easy to install because you dont need to change the lower plenum gasket...just buy a inlbs torque wrench at sears...use it clean it and return it....
Old Sep 8, 2006 | 07:18 PM
Andy2434's Avatar
Yes! . . . Most definitely.
Old Sep 9, 2006 | 05:29 PM
TURBOTOM's Avatar
a.k.a kleicoupe
mine wil be here on tuesday i cant wait!!!!
Old Sep 9, 2006 | 05:30 PM
with your pop charger its gonna sound sick.
Old Sep 10, 2006 | 04:09 PM
mrhager's Avatar
Why are Sedan owners buying the 1/2" spacer? The Motodyne web site indicated the engine cover will fit with a 1/2" spacer on the sedan!
Old Sep 12, 2006 | 06:58 PM
FenixL1P's Avatar
because most of us want the "across the power-band" gains for everyday driving that the 5/16 spacer affords us....
Old Sep 12, 2006 | 07:13 PM
jameyb's Avatar
+1.
jbelf23
Forced Induction
Oct 24, 2015 12:32 PM
CoupeObsession
Aug 17, 2015 01:05 PM
sick_sixspeed
Jul 20, 2015 10:25 PM
Soumilg
Jul 18, 2015 12:33 PM
