Car still pinging
Old Sep 11, 2006 | 10:12 PM
trey.hutcheson's Avatar
Car still pinging
The car is *still* frigging pinging. The catch can helped, but it wasn't a solution. There is an apparent corelation between the level of oil in the catch can and the amount of pinging; but even when it's empty, there's still pinging.
The knock occurs at part throttle, half throttle, full throttle, every gear, all across the rpm. I can be running in 3rd gear at 4k rpms, at approximately 20% throttle, and if I jump on it, it will knock. If I'm already at 50% throttle, then go to the floor, it will knock.
I'm sure my mods haven't helped, but they're not the cause. It knocked when it was stock.
I don't think it's an a/f problem, or fuel pressure problem. It will knock even in the upper rpms while WOT. And I've confirmed on the dyno that I'm running high 12's. It's either gas, or timing. I *always* use 93, and I've gotten the same amount of knock on Chevron gas as I have the cheapo brands.
I know there's even more power left in the car. I'm sure that if Sharif could get a hold of it, I'd see some pretty good gains. But I think I'm gonna wait until the accessport becomes available, or uprev brings something to market.
Old Sep 11, 2006 | 10:29 PM
Texasscout's Avatar
is it a high pitched ping that sounds like a small hammer on the side of the block or is it a deeper lower knocking sound?
Old Sep 14, 2006 | 11:31 AM
Sorry, just now saw your response.
I wouldn't really call it either. If anything, it sounds like rustling leaves, if that makes any sense.
Old Sep 14, 2006 | 11:42 AM
GEE PASTA's Avatar
Florida G35 Club
Trey
I would try a spark plug change, Iv seen sharp points on plugs, threads or carbon build up cause this problem. They will glow and cause pre ignition.
Old Sep 14, 2006 | 11:49 AM
DaveB's Avatar
Kind of like ball bearings in a can in the distance?
How certain are you that this really is pinging or detonation? Do you have someone in the area that can log the ECU and watch the timing and such? I thought I had some pinging too and then it turned out to be a loose piece of metal in the passenger side seat belt mechanism.
Old Sep 14, 2006 | 01:28 PM
Jeff92se's Avatar
Red Card Crew
I agree with Dave. It would be good to see an IGN curve from a datalog. Someone with a Cipher or Autoenginuity could do it.
Old Sep 14, 2006 | 01:55 PM
Pasta - I've considered the plugs. I may as well do it.
Dave/Jeff - I don't know anybody with any tools locally that can log the ecu. I had borrowed a techtom a few months back, and I watched the timing, and it didn't appear to have any odd patterns. In fact, other than shifting, the timing between my car and Cheryl's car were very close.
Old Sep 14, 2006 | 03:47 PM
memorex's Avatar
rusting leaves dawg? I know my boy's G had a deep ping also but it was his mods.
Old Sep 15, 2006 | 11:07 AM
GT-Ron's Avatar
"rustling" leaves... ...as in a pile of leaves blowing around.
Mine only started after the MREV, Headers, Cats were installed... ...so some of the low-RPM noise may be the added airflow pumping through the headers, which are hardly as soundproof as the OEM units.
Likewise, I wish I was near (closer than 3-4 hours) a good tuning shop to make sure.
Old Sep 17, 2006 | 12:09 AM
HARLEY G35's Avatar
what about the grade of gas ur using
Old Sep 17, 2006 | 12:10 AM
HARLEY G35's Avatar
right never mind just blind
chinee
Jun 10, 2024 07:48 PM
Tolboothwilley™
Exterior-Vendor
Jul 28, 2016 12:42 AM
marsman328
Northern California
Aug 11, 2015 07:29 PM
newg37
Jul 26, 2015 09:32 AM
Karnicle
Jul 23, 2015 05:08 AM
