Did some data logging last night with various "stock" intake setups
Originally Posted by bwassul
DaveB - very nice writeup! I'd be interested in seeing how the setup I have compares to these. My G coupe has a stock airbox and Z-tube with the Power Duct and radiator snorkel. The difference is that I removed the lower resonator that sits below the airbox. When I put the stock airbox back in after having a CAI for a while, I thought the resonator would rob me of some flow just like the resonator in the G-tube. I knew it might mean slightly higher temperatures but assumed that effect would be minimal given the location of the resonator opening relative to the filter.
Right now I'm experimenting and I've plugged up the lower airbox resonator with a squirt bottle cap. The induction noise is a bit deeper. Driveability doesn't seem to be impacted either.
Originally Posted by CBRworm
Any comparison Between G-tube And Ztube ?
Originally Posted by trey.hutcheson
^^^ I don't think so. When the radiator fan kicks in, my intake temps drop precipitously.
Cuz one time, I drove around for 20 minutes and when I got home, I popped the hood with the engine on and feeling around the pop charger. Then the fan kicked on and the rush of hot air nearly burnt my arm.
You know now that I think about it, I'm not so sure. I had the stock airbox then, versus the stillen airbox now. I haven't the opportunity(nor the tools) to datalog since I put on the stillen.
But from discussions with others regarding the various intakes, the stillen has slightly better cooling properties than the JWT; neither are very close to the stock airbox. Meaning, both the stillen and the jwt will heat up more quickly than the stock airbox, but they also cool more quickly than the stock airbox.
Originally Posted by badtziscool
Does it really? With an open air filter element?
Originally Posted by DaveB
So did you just remove the resonator and leave the hole open?
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
Julianpnce
Intake & Exhaust
Sep 1, 2015 07:41 PM
