Need "switched" 12V underhood power source
Old Oct 29, 2003 | 11:35 AM
DaveO's Avatar
I'm looking for an easily accessible "switched" 12V underhood power source. I would like to stay out of the IPDM E/R (Intelligent Power Distribution Module Engine Room) box if possible.
I want to use this "switched" 12V source as a control signal. The additional amp draw will be minimal.
<P ID="edit"><FONT class="small"><EM>Edited by DaveO on 10/29/03 10:20 AM.</EM></FONT></P>
Old Oct 29, 2003 | 12:10 PM
Meatshackle's Avatar
Deep Sea Moderator
Re: Need "switched" 12V underhood power source
What do you need power for? I just totally re-wired my car so I can help you if you give me some info.
Russ
Black w/willow, 6MT Coupe, nav, aero, V1, PS2, & TVs all up in the headrests.
Jax, FL
Old Oct 29, 2003 | 02:05 PM
GforceI's Avatar
G SQUAD
While we are talking about wiring, I just ran a power cable to the trunk and found that extra post on the positive terminal just a little too convienent. What is it really there for? From what I can tell so far it loses power when you start the car and that is the only difference. It's ok to use, right?
Old Oct 29, 2003 | 02:06 PM
redwillow's Avatar
20 Year Member
thats a tough one, i just looked into this and almost everything is gonna be in the IPDM.
03 6MT coupe, red/willow, premium, aero, splash guards, alum pedals, clear corners, 15% tint
Old Oct 30, 2003 | 10:18 AM
DaveO's Avatar
redwillow,
The only switched 12V power source I've found so far is to the EVAP canister purge solenoid.
I may have to change my mind and go into the IPDM E/R. Would you offer the benefit of your experience?
Thanks in advance,
DaveO
Old Oct 30, 2003 | 02:01 PM
redwillow's Avatar
20 Year Member
sure, i'll have to check the manual schematics again and get back to you. I never actually went through with connecting anything to the IPDM.
Old Oct 30, 2003 | 05:58 PM
redwillow's Avatar
20 Year Member
looks like IPDM pin 11 or pin 6. You'll need to check it with a circuit tester or mulitmeter.
You can find em on the IPDM if you check the service manual on page PG-25.
....If not, the ignition relay is in the IPDM and my guess would be that might work also. Again, you'll have to check it with a meter or tester.
Old Jul 28, 2005 | 01:33 PM
bythabay's Avatar
In my 2005 6mt G35 Sedan:
jilljann1
Jul 21, 2020 08:12 AM
bryanr
Drivetrain
Sep 30, 2015 06:31 AM
AuAltima3.5
Audio/Video/Electronics
Sep 13, 2015 11:48 AM
G35VSHNG37
Sep 10, 2015 01:54 PM
zcherub
Sep 10, 2015 12:03 PM
