Help Radiator needs to bleed how?
Old Nov 22, 2006 | 09:23 AM
RaFmAn123's Avatar
i took my car into the dealership twice already and the car keeps over heating they first bled my radiator and it works fine for like a day and then it overheats again so i took it back and they changed the thermostat and bled it again and it worked for a little and then did it again i want to take it into the dealer but its overheating i wanted to know if anyone knows how to bleed it i followed the upper radiator hose and found the bleeder screw i think thats it and i wanted to know the proper way to bleed it
Old Nov 22, 2006 | 09:41 AM
sdnpaul5at's Avatar
I had the same problem, the bleeder is right by the firewall next to the battery, first off remove it, get a funnel that will fit in the hole & start filling it with antifreeze, you have an air pocket, make sure the rad is full, with both rad & bleeder caps off run the car until you get even flow of fluid coming out, may take a while, you may want to have someone keep the revs up for you at 3000rpm to get all the air out, good luck.
Old Nov 22, 2006 | 09:43 AM
Brando's Avatar
You can follow this link to the page in the factory service manual....
http://www.g35frenzy.com/downloads/2...anual/B/co.pdf
Old Nov 22, 2006 | 10:09 AM
Ca$hio's Avatar
BradMD_96
Oct 6, 2015 09:31 AM
Usman Ali
Sep 22, 2015 06:59 AM
lavtxa
Sep 21, 2015 11:51 AM
yosip1115
Sep 9, 2015 03:30 PM
