Is an engine flush worth it?
Old Sep 10, 2007 | 05:43 PM
  #31
WILLIE BEANS's Avatar
Originally Posted by mswc
I normally use synthetic oil, but for the past few changes I've been using regular (and high mileage).
WHY WOULD YOU SWITCH FROM OIL ..TO SYNTHETIC ..THEN TO REGULAR THEN HIGH MILEAGE .??
Old Sep 10, 2007 | 05:45 PM
  #32
Jeff92se's Avatar
Red Card Crew
Originally Posted by imafukinrider
why Would You Switch From Oil ..to Synthetic ..then To Regular Then High Mileage .??
Why Not?
Old Sep 10, 2007 | 05:49 PM
  #33
jonnylaw's Avatar
Originally Posted by Jeff92se
Why Not?
Thought it was bad to go from synthetic back to regular, especially on high mileage cars.
Old Sep 10, 2007 | 05:50 PM
  #34
Jeff92se's Avatar
Red Card Crew
Myth..............It's not bad
Old Sep 10, 2007 | 06:44 PM
  #35
st1sj's Avatar
no need to flush and spend time waiting. just give the cash to the "techs" that recommended the service. it'll save you hours of waiting around.
Old Sep 11, 2007 | 05:41 PM
  #36
Still2Slow's Avatar
I took my car to get the oil changed recently (at 76000 miles) and the techs recommended I should get my engine flushed. Now when an engine is flushed, it's to get the sludge out right? Is this worthwhile to do on the G35? I've read some pros and some cons other places, but I can't seem to dig anything up on G35driver about anyone having their engine flushed. I normally use synthetic oil, but for the past few changes I've been using regular (and high mileage).
By all means don't listen to those idiots. If you've been using at least a group III oil -M1, PP or better you won't need it. Put some redline or motul in there if you want to clean it safely if you used shiet oil. But if you didn't you won't need to do anything. YOu could cause probs if you dislodged sludge from crap oil with a flush.
Jnm07
Sep 5, 2015 01:16 AM
Phenomenon9
Aug 9, 2015 01:34 AM
joedaddy1
Jul 28, 2015 02:58 PM
