Metal in Oil!!!!
Old Dec 13, 2006 | 04:47 PM
crza81's Avatar
Metal in Oil!!!!
Changed oil today and noticed bronze metal shavings in the oil!! 2005 g35 30k miles ...
Old Dec 13, 2006 | 05:08 PM
Old School's Avatar
You been hittin the rev limiter alot lately? only thing I can think of that's bronze is the valve guides.....but if the metal was burned, then it could be anything.
Metal shaving is normal in a new motor.....you kinda have me scratchin my head now.
Old Dec 13, 2006 | 05:13 PM
crza81's Avatar
I have 30k on the car i find it strange for metal to be in the oil . i hope its not my bearings!
Old Dec 13, 2006 | 05:21 PM
Old School's Avatar
yea, saw your mileage....that's what makes me scratch my head....new motors its normal.
Save em and take it to the dealer....maybe you can get a new motor if it turns out to be your bearings. If you're heavily modded, you might be SOL.
Old Dec 13, 2006 | 05:24 PM
Hi-TechG35's Avatar
Sounds like you are getting ready to shoot a rod through your block. If you are modded take them all off (includes intake, valve cover even different caps). Warranty will void you for whatever they possibly can. I had metal in a my pan on a few cars and boy oh boy talk about bad news!
Old Dec 13, 2006 | 05:27 PM
Jeff92se's Avatar
Red Card Crew
Take a sample and send it to Blackstone Labs N-O-W!
Old Dec 13, 2006 | 07:41 PM
DaveB's Avatar
Bronze? What in the engine would be bronze Silly question, but if you have a 6MT, are you sure you sure you drained the engine oil and not the transmission oil?
Old Dec 13, 2006 | 07:52 PM
Jeff92se's Avatar
Red Card Crew
DaveO I mean DaveB, I think bronze is used under the top coat of the crank/rod bearings.
Old Dec 13, 2006 | 07:54 PM
Fassster10's Avatar
Metal shavings? OOoOHHHhH Damnnn, i think you might be running metal against metal and most likely is the bearings, same thing happened to my F-150. Better return to stock ASAP and take the car to the dealer and if they repair it, you need to re-evalute what mods you have and what they are doing to the engine....30K miles is wayyyy to early to be having those type of problems....keep us updated!
Old Dec 13, 2006 | 08:37 PM
GreenGoblin's Avatar
The goblin resurrection
wow that is crappy def bring it in to the dealer
Old Dec 14, 2006 | 10:36 AM
ballisticus's Avatar
Very strange. If it's bad enough to see chunks of metal, you should have been hearing unusual things under the hood. Especially upon startup.
Any low clunk or knock that repeats every half second or so when you start in the morning? Ever overheat or have the oil light come on? Did you notice this upon draining it or was it on the dipstick or something? If upon drain, cut open the oil filter and see what is in there. That will tell you a lot.
Old Dec 14, 2006 | 01:01 PM
G35_TX's Avatar
My guess they were metal shaving, but looked bronze because of the oil coating them.
Old Dec 14, 2006 | 02:09 PM
GEE PASTA's Avatar
Florida G35 Club
Rod and main bearings have a high amount of tin in them. Bronze metal in the oil would make me think of the thrust plates, washers behind the cam sprockets. If the camshafts are walking around in the block this would be the cause. Still very scary finding metal in the oil. You could find that in the transmission very easy.
Old Dec 14, 2006 | 03:40 PM
Earl's Avatar
Has anyone inspected the timing chain tensioner. Could it be brass or bronze?
Old Dec 14, 2006 | 08:00 PM
Jeff92se's Avatar
Red Card Crew
Nissan has traditionally used plastics for the tensionor guides and for the end of the tensioner itself. But I haven't seen one for the VQ35 specifically
