Engine Oil coolers
There are tons out there.
http://store.summitracing.com/egnsea...839034&NeXID=5
But unless you have a turbo or track the car, there is no need for one. And even then, its not really needed if you use a good synthetic turbo rated oil. A better thing to spend money on is a ATF cooler if your coupe is a 5AT. That is a different story as even a 25F drop in fluid temp will extend the life of the tranny by years.
FS[SoEast]: 2006 DG Coupe Part Out - mrev2, projectors, etc
bu villain
Accessories
63
Aug 25, 2016 07:14 PM
