what i must do now???
Old Dec 25, 2006 | 02:04 PM
kuwait_G35's Avatar
hi guys am new in the site...
i wana ask ...
i have G35 2003 auto K&N air intake((long)),spacer 5/16 ,unothodox racing underdrive crank pulley,
i feel my car is not going fast ..soo what i must do ???
my car is not pulling in the 4th ????
Old Dec 25, 2006 | 03:34 PM
Calvin's Avatar
Overglorified Altima
all cars react differently to mods and dont always see a gain immediately. some mods will actually cause you to lose power. to fix this, get a tune. but i wouldnt recommend a tune until youre done with all your mods. jmho.
Old Dec 25, 2006 | 03:46 PM
extreme4377's Avatar
Lexus IS350
Next move, an exhaust system. Go with Fast Intentions. Youll get great gains, great sound, great quality, and excellent customer service. They're having a sale right now actually, check out the marketplace under the vendor section.
Old Dec 25, 2006 | 04:20 PM
sjc1789's Avatar
Florida G35 Club
hero is right.. you might not see a gain immeidiately.. an exhaust would be a good next mod.. try a ecu reset..
https://g35driver.com/forums/showthr...ight=ecu+reset
Old Dec 25, 2006 | 04:55 PM
kuwait_G35's Avatar
mmmm... but now i do not have money.... how a bout test pipe ???????
Old Dec 25, 2006 | 04:58 PM
rookie's Avatar
Are you a 5AT or a 6MT? 287hp or rev up motor? You mentioned 4th gear so it counds like you're an auto, doing a rear differential swap with a 6MT would be a simple boost in power.
Old Dec 25, 2006 | 05:14 PM
Calvin's Avatar
i dont think g's ever came with 287. youre thinking of the z i think.
Old Dec 25, 2006 | 05:16 PM
Calvin's Avatar
test pipes will definitely help. be sure to get resonated ones for minimal rasp. look into fast intentions test pipes.
Old Dec 25, 2006 | 11:45 PM
Hydrazine's Avatar
Can you dyno your car?
That would indicate if you have a problem and how much.
Old Dec 26, 2006 | 07:33 AM
kuwait_G35's Avatar
my car is auto......
somebody told me the problem is that the underdrive pully make the car electricety's down ...so i must buy Buddy Club Condenser Ground System....
others said that the air-intake get alot of air inside the engain soo i must but a test pipe in my exhaust to free the air ....
soo what do you advise me to do ???
1- buy Buddy Club Condenser Ground System?????
2-buy a test pipe ?????????
Old Dec 26, 2006 | 09:42 AM
Earl's Avatar
i wana ask ...
Is your car a coupe or sedan?
Old Dec 26, 2006 | 11:57 AM
DaveB's Avatar
Take the car to a 1/4 mile strip and make some passes and report back. That's the only real way to know if something is wrong.....and I doubt there is. The longer you drive a car, the more you get use to the power.
Old Dec 26, 2006 | 03:56 PM
solidskyline's Avatar
has someone mentioned to you do an ecu reset?
Old Dec 26, 2006 | 10:20 PM
kuwait_G35's Avatar
my car is coupe,,,
and yes i reset my ecu ...
Old Dec 27, 2006 | 01:48 AM
mistermojorizin's Avatar
after the mods, does the car feel slower than b4 the mods? or is it just not faster?
if i had to guess, the problem is probably the K&N intake. try taking it off and putting the original intake back off. I'd bet it'll feel faster in 4th gear again. the intake may make you loose torque, which makes the car *feel* faster, especially in higher gears where you are in lower rpms and torque makes more difference than horsepower.
if that is the problem, you can sell the K&N and buy a stillen intake.
edit: alternatively, if the car is not slower, but rather you are just dissapointed with the gains, you should keep in mind that n/a mods don't really add that much power.
