Spark plug which has the highest conductivity?
Old Jan 2, 2007 | 03:44 PM
infinitialex's Avatar
Spark plug which one has the highest conductivity?
I have heard that copper has higher conductivity then platinum or iridium spark plugs ,,is this true?
Old Jan 2, 2007 | 06:16 PM
badtziscool's Avatar
It probably does but that doesn't make it better than the platinum/iridium tipped plugs. Those metals are much harder than copper so you can manufacturer the plugs with a smaller surface area and thus concentrate the spark better and thus making it stronger.
Old Jan 2, 2007 | 07:46 PM
well as i understand form doing some brief research. Manufacturers preffer Platinum and Iridium not because of performance but for longetivity.
I am wrong here?
Old Jan 2, 2007 | 07:47 PM
QuadCam's Avatar
I am wrong here?
I believe you are correct!
Old Jan 2, 2007 | 07:49 PM
So copper will perform better but will have to be gapped over time..
Cheaper plug and better performance?
ANyone have any data on what pro guys preffer at the strip?
Old Jan 3, 2007 | 01:33 PM
OCG35's Avatar
bump
Old Jan 3, 2007 | 02:30 PM
redlude97's Avatar
copper plugs only last a year, so if you are willing to replace them often, then they are cheaper and better performing than platinum plugs
Old Jan 3, 2007 | 05:05 PM
very interesting info...I dont mind replacing them once a year to gain a hp or two. Plus gas mileage might get better too right?
Old Jan 6, 2007 | 12:34 PM
QuadCam's Avatar
copper all the way.
Old Jan 6, 2007 | 12:46 PM
QuadCam's Avatar
Here are picks of a brand bew NGK V-Power plug for our cars. I have some sitting in my garage for my next plug change. There are 1 heat range cooler than stock....stock gap though.
Part # is: LFR6A-11
the part number for the iridiums of the same size and heat range are: LFR6AIX-11
Old Jan 6, 2007 | 04:17 PM
Part # is: LFR6A-11
how much are those?
Old Jan 6, 2007 | 04:28 PM
QuadCam's Avatar
I don't recall exactly.....I think they are about $5 per plug.
jeffbdye
Jun 1, 2018 03:51 PM
g.spot
May 9, 2016 10:54 PM
KallDay86
Jan 8, 2016 12:42 AM
Patrick Bovee
Oct 1, 2015 10:42 AM
