Cam Question
Old Feb 19, 2007 | 08:24 PM
jnkirk1974's Avatar
Fastest G35 In Rockwall
Cam Question
Ok guys, I've used the search button and haven't found what I was looking for.....so hear it goes.
As far as cams go, which ones will help me more on the low end? I know that cams can really hurt your low end power and provide top end HP. However, I am somewhat looking for the opposite.
Which is the best out of the following:
JWT Cams
Tomei
Nismo
Drivability and idle are very important to me. I don't want something that's going to make driving my car miserable, but I'm definitely wanting to add power on the bottom end.
On another note.....is there an aftermarket throttle body that you'd recommend? I thought that Crawford made one, but I cannot find one.
Old Feb 20, 2007 | 12:38 PM
jnkirk1974's Avatar
bump
Old Feb 20, 2007 | 12:54 PM
GEE PASTA's Avatar
Florida G35 Club
The more duration and overlap you have in the camshafts, the more top end power you will have.
To much camshaft can destroy drivability.
The factory cams aren't bad at all, You could always just advance your cams one or two degress
That will help low end power and shift your peak power down.
Old Dec 4, 2007 | 07:50 PM
OCG35's Avatar
Bringing an old post back... I'm looking into the possibility of cams... recently had Osiris (with cam timing adjusted) - I'm confused by the varying info I've been finding... the post above, plus these two from another thread:
Originally Posted by QuadCam
you are going to lose low-end torque by advancing the cams..
you'd need to retard the cams.
Originally Posted by GEE PASTA
Advancing the cams will move the power band lower and faster.
The VQ Cams are degreed in stock with to much advance.
I would try 1 degread retard intake 2--2.5 degree retard exhaust.
This is much easier than a cam change? I have not dynoed my car sense the cam change,
But feel it made a good 20 ponies. Car ran 107mph in the 1/4 without slicks @ 4800 feet (Utah)
If anyone can clarify it would be great... I'm looking for more immediate low end trq...
Also looking for the response to the OP of this thread - what aftermarket cams are suggested:
Nismo (not high on my list)
JWT (which ones if this is the choice)
Tomei (I've heard a few good things, but not a lot of info)
GT Motorsport (I just happened to see a thread with these)
Or any others that might be worth while... If/when I get cams I will do headers as well and have the cam timing adjusted on dyno tune.
Viable info please, not theory.
Thank you.
Machine Head
19 Inch
Mar 16, 2016 08:55 PM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
INVADER_6MT
Sep 1, 2015 10:19 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
