Z tube / Popcharger install =)
Old Oct 21, 2007 | 01:03 PM
  #31
spddmn124's Avatar
dude... you know the "accordian" plastic piece coming out of the Tb... you dont need that... you can directly install the ztube right on to the TB... trust me itll fit better, i just installed mine yesterday.
Old Oct 22, 2007 | 03:56 PM
  #32
snavematt's Avatar
just a sedan
I took mine off as well, but still wondering where the heat shield is,
Old Oct 22, 2007 | 06:17 PM
  #33
Calvin's Avatar
Overglorified Altima
Originally Posted by Sir Boostalot
Of course its still worth it!! If you can get cold air into your engine that means better IAT's which equals more hp.
Yeh, but does the p/c allow colder air in? Especially without a heat shield, like this one...?
Old Oct 22, 2007 | 07:26 PM
  #34
snavematt's Avatar
just a sedan
Doesn't the heat sheild have dual purposes? Control the heat directed at the filter and on mine it looks like it would keep any rain that may get in past the engine shield from getting to the filter, your intake as shown in the picture looks like it would be bringing in more hot air than with the heat shield, since you are also not tied into the OEM air scoop. Just my opinion
Old Nov 3, 2007 | 02:46 PM
  #35
Still2Slow's Avatar
your z-tube looks different than mine, wft?
Old Nov 3, 2007 | 08:34 PM
  #36
O HELLA OEM's Avatar
how do u reset the ecu?? where is it? lol
Old Nov 3, 2007 | 09:38 PM
  #37
Still2Slow's Avatar
Disconnect the negative battery terminal and then pump the brake. That should do it.
Old Nov 4, 2007 | 11:17 AM
  #38
V35 Skyline GT's Avatar
6MT Coupe
ECU reset thread:
https://g35driver.com/forums/engine-drivetrain-forced-induction/6526-easy-ecu-resetting.html
The pc heat shield, though not the best, does also utilize the oem air dam that on top of radiator as mentioned before.
Plus lets you sport the CARB sticker that you should have too.
Pix of mine with heat shield that came with kit from JWT.
Old Sep 11, 2008 | 04:25 AM
  #39
n15m0's Avatar
Does anyone have a step by step guide or DIY to install the Z tube? I'm new to this so any pointers would help as I don't want to stuff it up. I just received my Z tube today to be hooked up to the factory airbox.
Thanks!
Old Oct 24, 2008 | 07:18 PM
  #40
NJzFinestG's Avatar
why does that ac line need to be protected??
Old Nov 2, 2008 | 09:16 AM
  #41
uf20wop's Avatar
so the MAF does not rub a hole in it when it's vibrating from the engine
it's an $800 fix
Old Nov 4, 2008 | 07:55 PM
  #42
RBurroughs's Avatar
is pop charger just a synonym for intake?
Old Nov 12, 2008 | 10:15 PM
  #43
RandomHer0's Avatar
Yes
CrazyLogic219
Aug 13, 2015 06:40 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
EnCr1pt3d
Jul 29, 2015 03:35 AM
netcbc
Engine - Intake/Fuel CDN
Jul 24, 2015 02:21 PM
