500+ horse power
Old Mar 3, 2007 | 05:29 PM
motiv3's Avatar
500+ horse power
I am thinking of using a JWT TT setup to generate 500+ horses. I know that I need to upgrade some internals and I am not the smartest when it comes to this. What all do I need to upgrade and what brands and parts should I use? and by everything I mean what size exhaust to use.
Old Mar 3, 2007 | 05:43 PM
Canadian's Avatar
Canada, eh?
For 500whp you should do a complete engine build is what I would say.
Someone move this to the FI section, or go check out my350z.com there is lots of FI info there.
Old Mar 4, 2007 | 04:22 AM
purpleacid's Avatar
^^^ +1
I just hope you're ready to spend a lot of money. It wouldn't necessary to do a complete engine build but you'd have to upgrade some vital parts like the camshaft. Check the FI sub-forum or hit up my350z...good luck man
Old Mar 4, 2007 | 05:01 AM
wa2good's Avatar
We have done many, many JWT TT installs. The built motor installs are about 500whp. Anything over 400whp on pump gas is grounds for a built motor in place of the stock one. For your 500whp goal, you would need to go with a built motor (about $5K+) This build would consist of a newly machined block & heads, a drop in compression ratio (to about 8.5-9to1 CR) with new stronger rods and pistons. Cams and other stuff would be optional. There are severall decent parts available for this build PM me and I will discuss this more with you in detail and offer you some advise.
Old Mar 5, 2007 | 10:57 AM
Vicg35's Avatar
Originally Posted by purpleacid
^^^ +1
absolutely!
Old Mar 10, 2007 | 03:08 PM
bossautosports's Avatar
You'll need money and also do tons of research BEFORE you spend any of that cash !!!
frank
Old Mar 11, 2007 | 01:00 AM
2slo2bfurious's Avatar
You have to buy and have it installed by an authorized dealer so just take it to them and they will tell you all your options then just take it back on here and figure out how much of it is a necessity and how much of it they are just trying to make $$ off of you. GL!!!
vamarris
Sep 26, 2015 12:56 PM
zcherub
Sep 10, 2015 12:03 PM
