short shifter problems?
Old Mar 31, 2007 | 10:57 AM
FaDz's Avatar
VIP
I installed a B&M short shifter... and when im reving high it makes a wired noise.... what could this be? (rattle)
Old Mar 31, 2007 | 04:08 PM
ryder198's Avatar
check under the car that there is enough clearance between ****er and exhaust heat shields. On some short shiftern installs i have had to take off heat shields and remove material. When you rev high the motor shifts on mounts and can move exhaust as a whole.
Hvae someone in car rev and go underneath to see...
Old Mar 31, 2007 | 04:32 PM
FaDz's Avatar
VIP
has anyone had this problem happen to them ???? with b&m short shiftER?
Old Mar 31, 2007 | 11:27 PM
BadBoy06's Avatar
g/l with yours..my buddy couldnt take all the probs
with his
Old Apr 1, 2007 | 06:29 PM
FaDz's Avatar
VIP
wow, so it has problems...
Old Apr 8, 2007 | 09:06 PM
OMyG's Avatar
I put one in my 04 and took it out in less than a month. Not only did it buzz but the shifting effort was ridiculous. The stock shifter has a rubber damper built into the shift rod to keep the vibration in check. The throws on the stock ain't so bad. I found a short shifter on 350Evo that has a damper - http://www.350evo.com/catalog/produc...7b99660a54f029
A touch pricey, though.
Anyone wanna buy my B&M?
Hasanbaloch
Feb 29, 2024 08:45 PM
cmesidewayz
Sep 29, 2015 09:28 PM
Jnm07
Sep 5, 2015 01:16 AM
BasquiatPicasso
Jul 23, 2015 06:26 PM
