Quick question
Old Apr 3, 2007 | 01:05 PM
1FSTG35AT's Avatar
Quick question
Ok I live in so cal where it can get to be a little cold during the winter, down to 14 degrees this past winter. I plan on getting my spacer but do I need to get the isothermal package because it does get hot in the desert or do I not need that package?
Old Apr 3, 2007 | 01:09 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
if it gets down to 14 degrees then you want to get the COPPER ISO-thermal upgrade with the spacer. That will prevent your throttle body from freezing up in cold temps.
-GP-
Old Apr 3, 2007 | 01:10 PM
1FSTG35AT's Avatar
Thanks!!
Old Apr 3, 2007 | 01:12 PM
1FSTG35AT's Avatar
no need for a tune after the spacer right?
Old Apr 3, 2007 | 01:15 PM
no, you would do a tune via utec/dyno time or TS reflash after you have done all your bolt on mods ei: intake, exhaust, hi flow cats, headers, spacer, mrev2. The tune brings all the mods together and helps them work in conjunction, which gives you more power.
-GP-
hydromaroc's Avatar
Don't bother... If "global warming" is coming you wont need the copper one... lol
Old Apr 3, 2007 | 01:16 PM
1FSTG35AT's Avatar
LOL global warming.... Ok so it will be a little bit before I need a tune then.
Old Apr 3, 2007 | 01:59 PM
BadBoy06's Avatar
damn..should have held off on that copper then..lol
408G35Sedan
Feb 23, 2022 06:46 PM
skippyG
Jan 25, 2016 01:18 PM
Th611
Oct 27, 2015 03:48 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
Soumilg
Jul 18, 2015 12:33 PM
