Innovate LC-1..
Innovate LC-1..
I am getting LC-1 kit tomorrow to use with Utec.. And while I was reading the manual I read it says that
"It is possible to install the wide-band sensor in place of the OEM oxygen sensor. In this case the
meter's analog output signal will replace the OEM oxygen sensor's signal to the fuel injection
computer. EFI equipped cars typically incorporate a narrow band oxygen sensor. These sensors
are typically 1, 2, 3 or 4 wire sensors.
The analog output connector of the LC-1 can simulate the operation of a narrow band sensor
while the wide-band oxygen sensor is installed in place of the OEM narrow-band sensor. Factory
equipped Analog output 1 of the LC-1 is programmed to simulate a narrow band sensor. Some
vehicles are equipped with oxygen sensors that do not produce an output voltage but change
their resistance depending on exhaust gas content. These sensors cannot be simulated. They
are used in less than 1% of all vehicles. Refer to your vehicles specifications if you think that
your vehicle may be in this category. The same is true for vehicles already factory equipped with
a wide-band oxygen sensor. These cannot be simulated either.
Some EFI-computers will create a fault when the heater power wires of the oxygen sensor are
disconnected. In this case mount the old oxygen sensor in a safe place (but not necessarily in the
exhaust) and connect the heater wires to it to keep the EFI-computer happy.
Be"
So.. My Question is.. Can I do this with our Car? I have 06' Coupe.. Other wise I'm going to get it welded on tomorrow when I pick it up.. Oh.. And where should I run the wire into the cabin?? Thanks..
Be"
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
marsman328
Northern California
Aug 11, 2015 07:29 PM
