mobil 1 question
Old May 9, 2007 | 03:28 PM
redlude97's Avatar
Originally Posted by MeetJoeAsian
I heard the OEM oil filter is only good for 3 months or 3k? or was that 5k? But in either case, if you use synthetic, is it better to use an aftermarket oil filter, like amsoil or something else?
Yes, extended drain intervals dont apply for OEM spec filters. Use an oil filter that is recommended for extended drain intervals such as the M1 or amsoil
Old May 9, 2007 | 07:49 PM
Jeff92se's Avatar
Red Card Crew
I might not be up to date on this but to my knowledge, there are no oil filters specifically designed for extended change intervals. From what I remember, Amsoil's oil can go for a long time, but their filters still need to be changed somewhat regularly. ie.. every 5-6k or so.
Old May 9, 2007 | 08:22 PM
redlude97's Avatar
That may be true for the m1 filter, but amsoil's EA filters are guaranteed for 25,000 miles or 1 year and are recommended for extended drain intervals. The mobil 1 filter is labled for "extended performance", but they don't recommend changing the filter until the oil is changed regardless of the mileage, which I would be leary of on an extended drain interval. So yes there are many filters suitable for extended drain intervals which don't have to be changed at 5-6k. It wouldn't hurt, but I'm not sure how necessary.
Old May 11, 2007 | 11:04 AM
HiTechOilCo's Avatar
Originally Posted by LazerRed1
Mobile 1 is no longer full synthetic.
Castrol 0W-30 (European Formula) is full synthetic as is Penzoil Platinum Synthetic, Amsoil's synthetics, and Rotella synthetic. All great oils.
German Castrol shows good oil analysis in the G35, All cars prefer different oils. Not one perfect for every car.
Visit bobistheoilguy.com. Lots of good info.
This is not so. Please, call Mobil at - 1-800-662-4525, and talk to them yourself. You will find that Mobil 1 is a true Group IV, PAO based synthetic oil.
Steve
CEO of Hi-Tech Oil Co.
Old May 11, 2007 | 11:08 AM
As an AMSOIL dealer of almost 20 years, I can answer this question for you.
AMSOIL EaO Filters are guaranteed for 25,000 miles or one year, whichever comes first, when used in conjunction with AMSOIL Synthetic Motor Oil in gasoline and diesel vehicles in normal service, 15,000 miles in severe service.
Steve
Old May 11, 2007 | 11:14 AM
Originally Posted by abcquackyxyz
dump m1 and get german castrol like lazerred said the bobistheoilguy forum is full of info!
Very questionable, "info", from very questionable, nameless and faceless srouces.
No reason at all to not use Mobil 1, a true PAO based synthetic oil. Call Mobil at - 1-800-662-4525 and find out for yourself.
Steve
Machine Head
19 Inch
Mar 16, 2016 08:55 PM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
INVADER_6MT
Sep 1, 2015 10:19 PM
Frostbite91
Aug 20, 2015 07:20 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
