problem with Idle......help
Old May 4, 2007 | 01:46 PM
Q45tech's Avatar
Yep the MMT caused the plugs to foul and this overstressed a few of the coil packs causing them to arc in well....................self inflicted damages.
Old May 4, 2007 | 03:44 PM
gregip1's Avatar
What's does "MMT" mean?
Old May 4, 2007 | 04:36 PM
DocJohn's Avatar
MMT = Methylcyclopentadienyl manganese tricarbonyl is an organometallic compound with the formula (CH3C5H4)Mn(CO)3. Marketed initially in 1958 as a supplement to the gasoline additive, tetraethyl lead to increase the fuels octane rating, MMT was later used in unleaded gasoline
Old May 5, 2007 | 01:59 AM
zenkisilvia's Avatar
lessoned learned
Yes, Sir. Nissan made that point clear to me that is exactly what happened. "self inflicted" damages.
Quite an expensive lesson I learned from all of this. I feel like a complete idiot since the bottle of Octane booster even has a warning on it that it is not meant for cars with O2 sensors and catalatic converters. I should have known better. I just hope my mistake can be a learning experience for others.
as far as the cost...it was for the plugs, coil packs, ECU flash, and labor. I also had them flush and replace my tranny fluid and engine coolant since it was already there, thought to go ahead and do some of the other maint. items.
Old May 5, 2007 | 02:22 AM
ttrank's Avatar
Grocery getter
That sucks. One expensive lesson.
bananax
Sep 24, 2019 12:24 PM
G35xdriver04
Nov 7, 2015 08:31 PM
itgogitrev
Sep 23, 2015 07:08 PM
mattdg35
Sep 14, 2015 11:28 AM
