Coupe Ignition TMG
Old Feb 4, 2003 | 08:08 AM
Msedanman's Avatar
O.F. Administrator
Coupe Ignition TMG
Could someone with the Coupe Service manual look up the ignition timing spec. The spec for the Sedan is 15 BTDC + or -
5 degrees.(at idle)
In the ESM for the Sedan it's listed under Ignition tmg, and sub menu : basic service procedure. ...Thanx..[img]/w3timages/icons/smile.gif[/img]
Gsedanman's Coupe
Old Feb 4, 2003 | 08:58 PM
VettRN's Avatar
Re: Coupe Ignition TMG
It's the same for the Coupe gsedanman.
FYI: Idle is 650 +/- 50 rpm in Park/Neutral with all accessories and lights OFF, at normal operating temp.
VettRN
Old Feb 4, 2003 | 10:28 PM
Msedanman's Avatar
O.F. Administrator
Thanks VettRN,...... So the timing the same for both cars.
Talk later..............[img]/w3timages/icons/smile.gif[/img]
Gsedanman's Coupe
Old Feb 7, 2003 | 10:45 AM
VettRN's Avatar
Yep.... According to my C Manual they are the same as your posted values.
chinee
Jun 10, 2024 07:48 PM
mike730
Jan 12, 2018 04:25 PM
djreinx
Engine - Electrical
Dec 10, 2015 01:48 AM
