clear radiator hose
Old Apr 29, 2007 | 02:57 PM
killerlexus's Avatar
clear radiator hose
does anone know if this is a save mod? can it with stand the pressure and heat of driving? is it just a clear tube attached with rubber hose ends?
saw this on a scion @ hotimport night
Attached Thumbnails clear radiator hose-clearhoses-copy.jpg   clear radiator hose-clear-hose-copy.jpg
Old Apr 29, 2007 | 08:14 PM
bkd's Avatar
bkd
I'm not sure if this is a special application product or just for show. Normal clear PVC hose isn't suitable for the heat and pressure of engine coolant. If you've ever cut through real coolant hoses you probably know they are thick walled and reinforced with threaded fibers.
It looks cool, but I wouldn't bet my engine on it.
Old Apr 30, 2007 | 12:31 AM
ttrank's Avatar
Grocery getter
Looks like standard plexi. I would think that it would be fine but it will get dirty and stained in a short time.
Old Apr 30, 2007 | 12:44 PM
Nickk6's Avatar
Its not standard plexi, if anything it would be polycarbonate. Plexi would melt when the engine warmed up.
Old Apr 30, 2007 | 01:00 PM
JOKER's Avatar
CLUB MODERATOR
WHY? WHY? WHY? Would you want this?
Old Apr 30, 2007 | 03:45 PM
ttrank's Avatar
Grocery getter
Plexi would not melt. I have polished ports and faces for speaker enclosures with a torch well past 300 degrees and it didn't show signs of breaking down.
Old May 1, 2007 | 12:00 AM
G SEDAN's Avatar
reminds me of a light saber (rated G)
reminds me of a ***** too (rated R)
get some samco hoses man......why clear? it's on a Tc...and IMO G35s are too high end for them.
Old May 1, 2007 | 01:37 AM
Nickk6's Avatar
Acrylic has a melting point about there...maybe even less. I've polished plenty of plastic and if you leave the torch there for a second to long the plastic will catch on fire. It will also easily bubble and warp, especially 1/8"....but I could still be wrong.
Old May 1, 2007 | 09:42 AM
ron4row2's Avatar
Don't quite understand the point of this mod... but if you like it then go for it.
Old May 1, 2007 | 10:08 AM
makes the car look ike a science lab.
Old May 1, 2007 | 12:10 PM
bert039's Avatar
^hahaha
I think you'd be safer with a clear intake tube.
Old May 1, 2007 | 01:35 PM
ttrank's Avatar
Grocery getter
Do both and add some neons under each!
Old May 1, 2007 | 10:22 PM
GIHDMR2's Avatar
HAHA atleast the TC can keep a tranny for longer than 50K miles. I wouldn't own one though, I don't like the way they drive.
Old May 2, 2007 | 06:53 AM
g35rcr's Avatar
you could be like a certain member here and just put a crap load of loom all in your engine bay to make it look retarded
Old May 2, 2007 | 07:40 PM
panda007's Avatar
what's the point of such tubing? other than the fact of transparency, will it have enough give to flex? i can imagine the tube popping off during hard driving...
