Fuse locations?
Old May 3, 2007 | 04:11 AM
zeer0's Avatar
Fuse locations?
Hi guys, I'm having trouble with my A/C not blowing cold air. I wanted to check the fuses for the A/C system, but the site that I use for the service manual has a broken page. I was wondering if anyone could tell me where to fine fuse #6, 12 and 19. Thanks
Old May 3, 2007 | 04:59 AM
AboostedG's Avatar
There are 3 locations. One is on the left side next to the pedals ( if you have a manual, remove the rest pedal to get to it ). Second is under the battery cover, just take it off and you should see it. The third is behind the battery which you'll have to pull up. Just reach back and lift up the lid on the black box.
I think its a 10amp fuse in the drivers left foot kick panel that you're wanting though.
Old May 3, 2007 | 11:11 AM
erdog's Avatar
Check to see if it is blowing cold air if you turn the temp all way down to 60 deg. If it is, then you have the same problem I had. The problem was that the sensor plug somehow came loose. In my 03, the harness was under the steering wheel, on the right side, above the black tube. You will have to pull down the steering wheel cover underneath to access it.
Old May 3, 2007 | 01:46 PM
zeer0's Avatar
No cold air at all. I have a feeling I might have a leak in my lines
G35-R
Nov 7, 2015 01:21 PM
ZoominG35
19 Inch
16
Oct 30, 2015 05:44 PM
ZoominG35
Audio/Video/Electronics
Oct 12, 2015 04:53 PM
2014g35x
Sep 11, 2015 07:53 PM
pasjr1972
Sep 1, 2015 10:17 PM
