How to reset the ECU after oil change!
Old May 10, 2007 | 12:15 PM
Hi-TechG35's Avatar
Quick question for those of you have a G with navigation. When it is time to change your oil the change oil and oil filter comes up on the nav display screen. How do you reset this feature after changing the oil and filter?
Old May 10, 2007 | 02:31 PM
Hi-TechG35's Avatar
Anyone?
Old May 10, 2007 | 02:36 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
i wouldnt be able to do it without looking at it cuz i dont have navi. Have you tried looking in the manual at all? It should be in there.
-GP-
Old May 10, 2007 | 02:39 PM
Hi-TechG35's Avatar
Read the whole thing and found nothing.
Old May 10, 2007 | 02:41 PM
Tru-G's Avatar
I have an 03 with nav and it is pretty straight forward for that year. Not sure how much has changed over the years but for an 03, push INFO then go to MAINTENANCE and then there should be an option for both the oil and the filter. Click on each and there should be a reset feature for both as well as being able to set your next oil change indication intervals. Hope that helps.
Old May 10, 2007 | 02:44 PM
Tru-G's Avatar
BTW...my Modificationitis has gotten really bad this month!
Old May 10, 2007 | 02:49 PM
Hi-TechG35's Avatar
Thanks.
LMAO...it will only get worse!
derres
Aug 28, 2015 03:27 PM
JoeMac
Aug 20, 2015 10:17 AM
linedr89
Aug 17, 2015 05:11 PM
ClwMike
Jul 23, 2015 12:55 PM
