mrev2 with 5/16 plenum on 03 coupe?
Old May 23, 2007 | 02:00 PM
805g's Avatar
i just purchased the mrev2 and the 5/16 spacer from md.
anyone know of the effects of this on a nonrevup engine?
Old May 23, 2007 | 02:08 PM
Calvin's Avatar
Overglorified Altima
you're more than likely to run lean and will need to get a tune.
a 5/16" spacer alone will suffice for non-revup engines. the addition of mrev2 will cause you to run lean until you get a tune.
shouldn't you have asked this questions before you bought the two?
Old May 23, 2007 | 02:13 PM
hai109's Avatar
I think you should get it reflash...I think someone here reflashed their ECU or got it retuned because the car will run lean...
Old May 23, 2007 | 02:19 PM
805g's Avatar
the guy with thmotorsports said it should add 11-13 horses. SO, i purchased the two together for a deal. just now cancelled the order.
Old May 23, 2007 | 02:24 PM
hai109's Avatar
For a REVup motor...Tony from motordyne...Or call him...he will tell you...He is the owner of motordyne...He's a nice guy...
Old May 23, 2007 | 06:35 PM
venommaxr33's Avatar
Must Go Faster!!
why did you cancel....best bang for the buck hands down. go with the utec for your tune. the mrev2 makes a bigger difference on the revup but still worth while on the non revup motor.
Old May 25, 2007 | 02:17 AM
by15vc's Avatar
if you got a good deal on it you shouldn't have cancelled. if you were worried about running lean..you could just install the spacer first then wait until u can pick up a utec and be able to tune once you install the mrev2. or just wait altogether and have them handy when you're ready.
Old May 25, 2007 | 04:47 PM
Ray@OCInfiniti's Avatar
there are lots of people worrying about running lean, and even thought this is the case most often than not with mods such as this, it's not a huge deal, not something that by itself will damage a motor or NECESSITATE a retune IMO. A retune can work sure, but it's not NEEDED. I ran every bolt on possible back in the day and only NEEDED a re-tune AFTER I installed cams....
Plus going with a new stand alone ecu like UTEC for simple bolt ons is WAY overkill IMO.
Old May 25, 2007 | 04:53 PM
Nismo G's Avatar
I was really confused about this in the past, but isn't the MREV the same lower collector that is already on the non-revup motor?
-Sean
Old May 25, 2007 | 05:31 PM
805g's Avatar
that is exactly why i cancelled my order.
Old May 25, 2007 | 06:45 PM
Skaterbasist's Avatar
Retired SuperMod
The MREV[2] is not exactly either collector of a rev-up or non rev-up.
It's a modified non-revup collector which helps in either rev-ups or non-revups, preferably revups. But for a non-revup, it tends to cause you to run more lean than it would on a rev-up.
Talk to Tony, im sure he will help you.
Old Jun 10, 2007 | 10:36 AM
Da-G-SpoT's Avatar
I spoke to Tony about this same situation. My 05 A/T coupe would run lean if i did MREV2 + 5/15 th ISO. I came back to him and let him know that i was also thiking of a Technosquare Re-flash, thats when he came back and said it would be worth while. For the price though, the Non-Revup engine would not benefit much from the MREV2 if you are comparing $$ per horses. As for the rev-ups its a worthwhile investment. Unless you have rich parents who bought your car and can give you the money, get a great deal on it or just want to blow some bucks for small gain on a non-rev up get the MREV2. If not, Get the 5/15th or 1/2 spacers and you would do just about the same. ^_^
Old Jun 10, 2007 | 10:51 AM
gary c's Avatar
'03 Coupe upgrade........!
Originally Posted by 805g
that is exactly why i canceled my order.
Your coupe will benefit the most from just the MotorDyne spacer ISO either
the 5/16" or 1/2". With the 1/2" spacer you'll lose the engine cover (no
longer fits). Looks like you learned your lesson about ordering "stuff" without
doing some research. When you order your exhaust system do a search
before you buy.......LOL
Old Jun 16, 2007 | 09:07 PM
Da-G-SpoT's Avatar
I also e-mailed Tony about getting the 1/2" spacer and still having the cover fit and h said that SOME people have been able to fit it in. They have trimmed the cover here and there and have made it fit. Again, this he says varies from vehicle to vehicle, hopefully i am one of those lucky ones! I am going to give it a try this weekend coming up.
Old Jun 17, 2007 | 12:26 AM
Calvin's Avatar
engine cover FTL
deathsupport
Canada
Aug 2, 2015 10:13 AM
andresito7
Aug 1, 2015 04:53 AM
sick_sixspeed
Tuner & Dyno
Jul 21, 2015 03:23 AM
