Pulleys owners: how's the NVH?
Old May 31, 2007 | 11:14 PM
trey.hutcheson's Avatar
First - be warned. This thread is not to discuss the merits, faults, price, or effectiveness of pulleys. It's not about engine/bearing wear, or about dyno numbers, or physics equations, or if modern american v8 cranks are balanced. This thread will be heavily moderated. Any regression into typical pulley debates will be deleted.
So here's my question for pulley owners: how have pulleys affected the NVH of your car?
I'm not asking because I'm considering purchasing pulleys; I'm not, nor to I plan to in the future. I was just driving around tonight and thought about the fact that since I had my aftermarket flywheel installed, the car in general is more raucous. There's definitely more vibration in the passenger compartment, and when I have the a/c on, I can feel it through my feet, the clutch, and the shifter.
I know the stock flywheel dampens a certain amount of these vibrations, as does the stock pulley. I assume aftermarket pulleys would have similar effects on NVH as lightweight flywheels. Am I wrong?
Old May 31, 2007 | 11:53 PM
OCG35's Avatar
Trey... a pulley question?... You know the outcome of this... it ALWAYS ends the same way.
Old Jun 1, 2007 | 12:09 AM
DaveB's Avatar
No, you're right. With an automatic, you probably won't notice much of a NVH increase because the TC is an ideal damper. With the 6MT, you'll notice it a little, but nothing like adding a lighter flywheel which does away with the dual mass assembly. With my old 5MT VQ30, I noticed a bit more vibration above 5000rpms with the UR UDP. The VQ30 is far smoother than the VQ35, therefore the difference in NVH was much more pronounced. It's too bad the larger VQs can't run as smoothly as the VQ30. I guess it's a trade off though. I'd rather than the additional torque and power
Old Jun 1, 2007 | 10:43 PM
Aznteazer's Avatar
i never noticed any NVH once i had the pulley installed. my car redlined fine with no additional vibrations that i could consider.
however, once i had my flywheel/clutch put in, NVH was very noticeable but i dont mind that at all really.
Old Jun 7, 2007 | 06:38 PM
shooter's Avatar
It's not the critic......
I installed the crank pulley on my 5AT and did not notice any increase in vibration, just a perkier (is that a word ;-)) car
seagrasser
May 3, 2022 09:43 AM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
NailBomb
Oct 28, 2015 07:53 AM
G35-2004-mt6
Sep 11, 2015 04:16 PM
