Supercharged or TT 5at sedan?
Jun 8, 2007 | 03:12 AM
anyone ever attempt that? or is it not even worth a try.DOMO
Reply 0
Jun 8, 2007 | 03:15 AM
its been done time and time again.
-GP-
Reply 0
Jun 8, 2007 | 05:48 AM
Check out the Forced Induction Forums if you haven't already....tons of info on this
https://g35driver.com/forums/forced-induction-24/
Reply 0
Jun 8, 2007 | 04:52 PM
Anything on the coupe will be the same for the sedan.
Reply 0
Jun 8, 2007 | 05:39 PM
it's all doable on the sedan, might require some modifications for things to fit since the engine bays and orientation of some items are different between the coupe and sedan
Reply 0
Jun 11, 2007 | 02:41 PM
The Greddy TT kit fits fine. It is very tight but does fit. You might need to modify your front end for an IC depending on what kit you pick. I did.
The Stillen SC's heat exchanger fits with no mods.
Reply 0
