tune up when?
Old Jan 15, 2004 | 07:39 PM
imRACERX's Avatar
tune up when?
got my car approaching 3400 miles. never had it serviced for anything. when do i need to bring in for the first tune up? should i get synthetic? should i take to other than infiniti? how much is it at infiniti? etc etc thanks RacerXXXXXXX
Laser Red, Willow, 6MT, Premium sport package, Clear markers w/ hid bulbs, Platinum 20% mirror tint, JL Audio W7 13.5
Old Jan 15, 2004 | 08:57 PM
Meatshackle's Avatar
Deep Sea Moderator
Re: tune up when?
3750 is the first maintenance checkup and it's just an oil change. You can even go 7500 if you don't do a lot of stop and go or drive hard. I switched to synthetic my first change. Look in the little maintenace book they gave you and it will explain everything they check and replace at each interval.
Russ
Black 6MT Coupe
Jax, FL
PS2 and Headrest thread
Old Jan 17, 2004 | 11:10 AM
ncozby's Avatar
Re: tune up when?
First tune-up is at 100,000 miles.
<font color=blue>04 DG/G Coupe 5AT - St. Louis, MO
Premium, Aero, Performance, Splash Guards
Metallic Tint - 5-Wire Grounding Kit
MB Quart / Eclipse Stereo
PIAA Extreme Whites - K&N Drop-In</font color=blue>
Old Jan 17, 2004 | 03:52 PM
JustinP10's Avatar
Re: tune up when?
Depending on how hard your car is driven and the environment you're in, I'd probably start checking thigns more closely around 20-30Kmiles, maybe longer.... Just depends how you are. I will personally check things out much more frequently, but that's just the way I am. I'm sure you could go 50-60K and still be ok too. The manuals and stuff have a guide in them, but it also says that it will vary depending on the conditions, etc...
If you take your car into the dealer for service, warranty items, recalls, etc.. they're supposed to do a full car inspection while it's in there and they should find anything that's out of the ordinary too, that is if you trust your local dealer....
Justin McClanahan
Heavily Modified 95 Infiniti G20
Working on a G35 Project Coupe
http://www.EverythingG35.com
Old Jan 19, 2004 | 09:05 AM
malx's Avatar
Re: tune up when?
Just be safe and tune it up. You also have to get one at 7800 miles and one at 15k. The dealership is going to try and tell you to not go synthetic for one main reason: they want to do more frequent oil changes on your car. Just make sure you get your tune ups when you need them, don't push it you know?
Thanks - Joey Avino
g.spot
May 9, 2016 10:54 PM
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
AJC128
Nov 1, 2015 11:55 AM
Usman Ali
Oct 4, 2015 08:23 PM
pdexta
Tuner & Dyno
Sep 2, 2015 01:03 PM
