changed to royal purple
Old Jul 1, 2007 | 05:16 PM
g35ctuner's Avatar
Thumbs up changed to royal purple
well after alot of research (and i get a fat discount) on royal purple oil i decided to change the dino oil out to synthetic. initially i didnt notice much but after about 50 miles of driving im starting to notice a difference, the car revs smoother accelerates smoother and just the over all driving experience is alot smoother. did it add hp? it sure feels like it. could just be because i changed the oil, or royal purple really does what it says. either way i like it and i will continue to use it. 04 w/40k miles used 5w30
Old Jul 1, 2007 | 05:51 PM
Nismo G's Avatar
I have been running royal purple for 20k miles now i think and i love it! Just rolled into 97K miles and switched from 5w-30 to 10w-30 and what a difference. Everything seems "sealed" now.
Royal Purple FTMFW!!!
-Sean
Old Jul 2, 2007 | 03:21 AM
Beebo's Avatar
Royal Purple
Old Jul 2, 2007 | 09:35 PM
zer0vdub's Avatar
so it is OK to switch to full synth after 40k? I have 47k and I was told that I couldn't because it would mess up the seals in the motor..
Old Jul 2, 2007 | 09:37 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
whoever told you that is a tool.
-GP-
Old Jul 2, 2007 | 10:41 PM
zer0vdub's Avatar
or I am a tool for believing it.. So I am going to be ok switching?...
Old Jul 2, 2007 | 10:43 PM
no you're just not as knowledgeable as some one that knows cars well. You will be perfectly fine to switch to synthetic at 47k, especially if you're switching to Royal Purple.
-GP-
Old Jul 2, 2007 | 11:43 PM
ballisticus's Avatar
FWIW, this comes from an Amsoil site, but these findings explain the difference you feel.
http://www.performancemotoroil.com/R...rple_info.html
The higher volatility is probably due to a lower grade basestock boosted with the moly additive to appear to be a superior lubricant (for a while at least). Another option is the German Lubrimoly. http://www.liqui-moly.com/web/lmhome...es/index_flash
Some NAPA stores have it.
Moly Disulfide is a very good solid lubricant/friction modifier, but it is generally not recommended for long service as it can begin to precipitate as the additives intended to prevent that deplete. Its a short-term racing lube that likely adds a few HP by reducing internal friction, but just don't expect to keep it in for more than the 3000 mile mark. And think twice about using it with a very efficient filter that have absolute ratings in sub-10 micron range. It wont take long to blind the filter and cause it to go into bypass mode and make it totally ineffective. BTW, I have nothing to do with Amsoil and I don't even use it in my cars. I do use their excellent 10W/40 motorcycle oil year-round and it does the job.
Old Jul 2, 2007 | 11:49 PM
cungkpham's Avatar
would you mind telling me who your hook up is?
Old Jul 2, 2007 | 11:50 PM
+1... Group Buy????
-GP-
Old Jul 3, 2007 | 11:49 AM
joe603's Avatar
I use 10W-40...but it gets hot in Atlanta! I love Royal Purple, been using it for years on all my cars.
Old Jul 3, 2007 | 11:52 AM
Jeff92se's Avatar
Red Card Crew
Anyone reading this? It's one of the best posts on oil I've read on this forum.
celwin
V36 Engine, Exhaust, Drivetrain & FI
11
Sep 28, 2015 03:52 AM
mikemf8
Sep 3, 2015 08:01 PM
