trying to install oil pressure gauge, where does it plu ginto at???
Old Jul 10, 2007 | 01:31 PM
iJeff's Avatar
a shop was saying its usually near the oil filter.
Im a noob to gauges and i had it wired up so its working, but we didnt have time to run the actuall sensor and wires for the sensor, so the guage isnt reading the pressure.
The wires to be ran comes out by where you pop the hood, could someone please help explain the best way to run the wires to wherever they need to go, and where to install the sensor.
Its on a 2003 G coupe. I was told it installs into the factory sensor which is just the idiot light???? i dunno, lol thanks guys!
I wanna do this tonight
Old Jul 10, 2007 | 10:14 PM
iJeff's Avatar
anyone?
Old Jul 11, 2007 | 01:27 PM
rcdash's Avatar
what kindo of sensor do you have? autometer senders are a 1/8 npt fitting. You can get an oil filter sandwich plate that will provide you two 3/8 npt fittings. so you need some fittings to do the conversion and you need to block the 2nd hole (the sandwich plate is used to allow hook up of an oil cooler). Or you could use the 2nd hole for an oil temp sender.... Does that make sense? if it doesn't go to a site like summit racing and look at what the oil filter sandwich adapters look like and you'll get an idea of how to hook it up (the sandwich adapter screws in between the oil filter and the oil pan).
Old Mar 8, 2008 | 06:23 PM
06g35meister's Avatar
what is our thread pattern?
Old Mar 9, 2008 | 06:27 AM
Xblackg35X's Avatar
sponsors on here have it for real chaep just ask
mtlruss
Dec 20, 2015 01:51 PM
usingthejohn
Media Share G35 Sedan V35
Sep 17, 2015 11:37 AM
RA102223
Aug 15, 2015 09:24 PM
TWASkyliner
Aug 1, 2015 11:43 AM
