CAMS
Old Jan 20, 2004 | 10:18 AM
2k2MaximaRIP's Avatar
CAMS
Has anyone gone ***** out so to speak and upgraded thier cams?
Old Jan 20, 2004 | 11:20 AM
glennp_1999's Avatar
Re: CAMS
Are aftermarket cams already available for the G?
<font color=blue>04 CB COUPE / WILLOW / PREM PACK</font color=blue>
Old Jan 20, 2004 | 01:08 PM
RacingDynamcs's Avatar
Re: CAMS
amuse makes them but recmds them to be used with their hi tech rom software ....
*pipes +15rwhp
Old Jan 20, 2004 | 03:01 PM
Carlos3186's Avatar
Re: CAMS
there are several comanys making them. nismo has a set that gives u 15 HP also JWT makes them for plus 16 HP sombody else makes them i think temoni or somthing like that i have no idea how its spelled but they have 3 deffernt sets out. check out my350z.com there are several people who have gotten cams
<a href="mailto:Carlos3186@hotmail....otmail.com</a>
Old Jan 20, 2004 | 03:36 PM
XLR8SN's Avatar
Re: CAMS
The cams are made by Tomei. Durations are like 256, 264, and 268 degrees. With the higher duration and higher lift, I believe that you will need to upgrade the valve springs and internals.
Old Jan 20, 2004 | 04:23 PM
Micah's Avatar
Re: CAMS
And if I remember correctly, the JWT cams are 260 and the NISMO cams are 262. You don't need to upgrade internals for cams. Stronger valve springs are a good idea, though.
Old Jan 20, 2004 | 07:23 PM
XLR8SN's Avatar
Re: CAMS
Sorry, what I meant by "internals" I meant everything that supports the new cams due to the higher lift and increased duration. If you are going that far into the engine, I would suggest working on everything at the same time,...complete engine rebuild. Heads, cams, valves, rods, pistons, flywheel, clutch, and anything else that you were planning to do. Makes the labor cost a little lower vs. having to take it apart everytime. Then again, if you can do this on your alone then,............................ just ignore me. :-)
Old Jan 20, 2004 | 07:34 PM
Carlos3186's Avatar
Re: CAMS
yeah well thats a lotta work to alone. it took 3 of friends to rebuild my buddys camero's engine. like u said though do it all at once cuz u are looking at 2 grand to take out the engine and work on it.
Old Jan 21, 2004 | 11:35 AM
Micah's Avatar
Re: CAMS
Good info. I remember your car from maxima.org years ago. What is the stock cam duration on the G35c?
Old Jan 22, 2004 | 11:42 AM
Micah's Avatar
Re: CAMS
If that's the case, even a 260 would be a big improvement, while not being aggressive enough to cause drivability issues, I would think.
brianuc4
19
Apr 10, 2020 02:12 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
MThawkins86
Oct 24, 2015 02:07 AM
UT G35
Sep 3, 2015 03:58 PM
