Low RPM or normal?
my 07 6mt is slightly higher, but not by much....no mods here so i'm guessing it runs low all the time
Its not low, if you see the first tick mark after the 0 then that's about 500 rpms and your car is running around 650 RPMs which should be normal. Now, if it dips lower when you're in drive then you have a problem.
