03 Couple g35 stalls out
Old Aug 20, 2007 | 09:34 AM
specialist's Avatar
Angry 03 Couple g35 stalls out
When you turn on you car when it hasn't been driving for a while it turns on. then you go for a drive for about 20 mins then turn off your car. wait a sec then try to turn on the car. It turns on but the rpms go up then drop then stalls out. I am in neutral with clutch down just a note
I don't know what to do.
DOMO
Old Aug 20, 2007 | 09:58 AM
specialist's Avatar
i have 350z tube with pop charger, grounding wires, Jim Wolf Technology G35 Clutch and FLywheel Combo, greddy exhaust dual
Old Aug 20, 2007 | 11:03 AM
myDOORSgoUP's Avatar
take your battery to a auto parts store and have them check it out....mine had been sitting for a while and the batt died out....i recharged it and everything seemed fine for a few days but then i had the same problem....after replacing the battery it did it 3 more times before starting up and staying on as if nothing had happened....later tested the old battery and found out it had a short..
Old Aug 20, 2007 | 11:09 AM
specialist's Avatar
oh yea i bought a new battery yesterday red top still does it
Old Aug 21, 2007 | 09:11 AM
specialist's Avatar
bump
Old Aug 21, 2007 | 12:15 PM
g35rcr's Avatar
a battery woudnt force a car to stall out, sounds like either you overoiled your intake and the maf sensor needs to be cleaned, or you have a leak
Old Aug 21, 2007 | 02:29 PM
RebelinRI's Avatar
Probably your TPS (throttle position sensor) Car doesn't know where the the throttles position is. Reset ECU and you could also do a TPS learning program. You can reset the ECU by discounting the Neg. cable for overnight. If you have troubles after that, try the TPS learning. You can get this at Motordynes website. It's on the end of the MREV2 instructions and here too. Do a search. Hope it helps.
Old Aug 21, 2007 | 02:41 PM
Deezflip's Avatar
This situation happens to many people on here, and most of them experience it from disconnecting the battery in order to do their mods and then reconnecting them when done.
I've heard maf sensors, computer re-learn, intake mods, aftermarket audio wire faults, etc.
Mine stalls on start up to this day and all i did was disconnect the battery to remove my CD's on my sucky a$$ bose headunit.
Old Aug 21, 2007 | 03:28 PM
bull3t's Avatar
sounds like a dirty throttle body to me
Old Oct 30, 2008 | 02:55 PM
AARONHL's Avatar
Same thing happens to me. All I did was disconnect the battery over night! What is causing this? I'm going to try to do the Throttle Relearn though.
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
laksjd84
Jul 24, 2015 05:12 PM
apintojr
Jul 23, 2015 10:52 AM
Karnicle
Jul 23, 2015 05:08 AM
Ninjay16
Jul 20, 2015 01:21 AM
