engine idle is messed up
Old Aug 25, 2007 | 03:56 PM
brianyun's Avatar
i just installed a skunk2 plenum spacer but the engine idle is really wierd. is it normal to go down about 100-200 rpms? and sometimes when the car is just sitting there in idle it goes down to like 500 sort of studders and goes back up
does anyone know whats going on?
Old Aug 25, 2007 | 04:11 PM
brianyun's Avatar
do you think it could be a leak?
Old Aug 25, 2007 | 04:31 PM
brianyun's Avatar
it also throws a engine check light
Old Aug 25, 2007 | 04:44 PM
codeflux's Avatar
definitely check for leaks, retorque all the plenum bolts, and reset the ecu.
Old Aug 25, 2007 | 05:07 PM
brianyun's Avatar
how would i check for leaks? i didint use sealent but i cant hear hissing
Old Aug 25, 2007 | 05:08 PM
brianyun's Avatar
and im sure all the hoses that i disconnected are put backtogether...would engine coolent be a factor? because it said to drain it but i didint..
Old Aug 25, 2007 | 05:21 PM
The1&Only's Avatar
I have a MD spacer, but I'm sure it's not that different. I would definitely check if all the hoses are sealed tight. I had that same problem after my 1st install. Codeflux pretty much covered it all. Make sure you do the ecu reset, my idle went back to normal after the reset.
Old Aug 25, 2007 | 06:23 PM
brianyun's Avatar
how do you do the ecu reset? ive done the easy one..many times but after i got this spacer in it doesnt work???? what way do you reset it?
Old Aug 26, 2007 | 07:07 AM
OCG35's Avatar
try this:
Old Aug 26, 2007 | 06:50 PM
Rphillips6487's Avatar
I would definetly be worried about something like that. Hopefully some of the other guys using the skunk2 spacer will tune in and give some advise
Old Aug 26, 2007 | 10:36 PM
brianyun's Avatar
hmmm thank you
Old Aug 27, 2007 | 05:42 AM
BW350GTskyline's Avatar
i installed a APS tall boy plenum on my 04 coupe.. it was supplied with 4 10m bolts.. the stock plenum has 6 bolts that go through to the lower plenum to secure it.. i wasnt pay attention and realize that the 4 bolts supplie with the new plenum were to cover the 4 bolts that go through to the bottom.. i experienced the same problem you r.. make sure the holes are covered with the supplied screws
Old Aug 27, 2007 | 11:33 PM
cungkpham's Avatar
isnt there a nipple with a plastic cover on it? somewhere on the plenum, not the spacer... maybe that nlack plastic/rubber nipple cover fell off? Engine coolant will not mess up your idle. you definitly have a leak somewhere (from what it sounds like)... you can also use propane gas... connect the tank with a hose and turn it on slowly... if you have a leak, it will pull the propane gas in the spacer, and make ur engine run smoothER. so that way, you know where the leak is.
Old Aug 28, 2007 | 12:48 AM
bull3t's Avatar
do a vacuum test, or use an automotive stethoscope...our engines make a hissing sound normally so you might not have a leak...i think it might have
something to do with your throttle body...my guess is that your TB got out of whack (sometimes happens when you disconnect the wiring/touch the
butterfly)...return it to stock to see if it still does it...if it returns to normal you probably missed a step during your install...if it still does it after you
return it to stock take it to the dealer...if you still have your warranty they'll recalibrate it for free...oh yea also try the motordyne reset procedure that
OCG35 posted...it'll take a few trys to be able to do the idle air volume learning procedure but don't give up...
Old Sep 19, 2007 | 11:03 PM
tommyngo9955's Avatar
I did the relearning proceduce but the check engine light is not blinking so I guess you need like a special tool to make the check engine light blinking? my idle is normal but check engine light keep come on with the same code P-0507 air idle is (too high).
Freeman186
Sep 6, 2023 10:07 AM
Joe Gargano
Sep 18, 2015 11:17 AM
Jnm07
Sep 5, 2015 01:16 AM
n2fooz
Sep 4, 2015 07:46 PM
