want to build my car up to 300whp possible?
Old Aug 28, 2007 | 01:13 PM
specialist's Avatar
i just got a quote for supercharger kit vortech non polished 5300 plus taxes is that expensive
Old Aug 28, 2007 | 01:29 PM
ISMSOLUTIONS's Avatar
Yes...call superchargersonline.com - tralk to Tony and tell him Rick from Fast Intentions referred you.
Rick
Old Aug 28, 2007 | 01:31 PM
Jeff92se's Avatar
Red Card Crew
Do you have Harry Potter bedsheets too?
well my problem is that i have a problem of saving alot of money at once. so i would like to buy part by part just stuff them under my bed . I don't think you can buy a turbo kit piece by piece. if i could i would buy greddy kit piece by piece.
Why are you guys even replying?
Old Aug 28, 2007 | 01:37 PM
specialist's Avatar
i was just tring to be funny. I will store them in my garage. is that better OMG
Old Aug 28, 2007 | 01:39 PM
Jeff92se's Avatar
Red Card Crew
Originally Posted by Jeff92se
Exactly what cams? Pistons? Rods? retainers?? Springs? Injectors? and what tune?
So any idea yet?
Old Aug 28, 2007 | 04:22 PM
specialist's Avatar
Eagle Forged Rods
RC Injectors 550cc
JE piston compression 10.5:1 look for a 11 compresion i think cosworth makes it but not to sure
Titanium valve train (retainers and springs)
Cam stage two
P&P, 4-angle Inlet Valve job
knife the crank
Valves
emanage ultimate
some header ???
maybe a throttle body not sure
This is a rough build
have ehaust already
Old Aug 28, 2007 | 04:48 PM
tekknikal's Avatar
as posted its possible but pricey.
consider why you're doing it and what your real goals are.
beyond that ...if it were me and that's what i had to do id be contacting the tuners out there who were also trying to get it done (iirc crawford was one of them)
Old Aug 28, 2007 | 04:49 PM
Jeff92se's Avatar
Red Card Crew
There's only about 3 things on that list that actually make power.
Old Aug 28, 2007 | 04:51 PM
tekknikal's Avatar
just read your other post... a word of caution: if something breaks you'll be out of a car, possibly for a while if you don't have the cash to fix it right away. pushing a motor beyond its limits on a super tight budget might not be wise.
having said that i still think you should contact tuners about this, and keep searching the forums for people who have seriously attempted before
Old Aug 29, 2007 | 09:26 AM
specialist's Avatar
thanks for you help tho
Old Aug 29, 2007 | 09:40 AM
lancer's Avatar
+1, take a look at what your goals are and what your budget really is.
You may want to discover automatic draft savings or paycheck deduction
It seems stupid to me to rip up your engine and put in a bunch of aftermarket parts that you don't need when you could spend $5k and get the vortech kit.
Why are you skittish about FI? Reliability? The vortech SC setup is very reliable, I want to eventually do one myself. Just don't over-do it.
just my .02
Old Aug 30, 2007 | 09:21 AM
specialist's Avatar
I just had a lot of problem with my prelude. I spent about 20 grand on the motor everything you could do for the engine. I was running 28 psi. i had 498whp i know it is a different car but i am just afraid that is all
Old Aug 30, 2007 | 09:30 AM
Hi-TechG35's Avatar
It can be done but like everyone says it will cost some change and some time.
Old Aug 30, 2007 | 10:19 AM
RebelinRI's Avatar
Look over at my350z.com There is a guy (Adam) that did an N/A build with all internals and what not to achieve I believe ?304/306? whp. Cost him a lot but he stayed N/A. Be prepared to pay big bucks to get there. It's up to you how you get there. Noz would be super cheap and then there is FI. Stock block can hold out pretty good but it's your coins. My set-up cost me under 2K and I can run my numbers all day on my stock block. You pick.
Old Aug 30, 2007 | 01:11 PM
  #30
specialist's Avatar
what happens if you use up all your nos you can't run the same number. I have never used nos
