Crank Pulley bolt won't come off
Old Sep 23, 2007 | 04:57 PM
App6MT's Avatar
Littering and...
Trying to put on my UR crank pulley and I can not get the bolt off. Any suggestions?
I tried the 5 o'clock trick with the cheater bar and turning the car over. No luck.
Tried brute force with a 2.25 ft torque bar, didn't budge. Maybe it will just have to wait until I feel the need to pull the radiator.
Old Sep 23, 2007 | 05:45 PM
ISMSOLUTIONS's Avatar
There is flywheel/pressure plate inspection cover - lower driver's side of the trans - on the front. Remove the plate. Wedge a pry bar in the teeth to lock everything in place. The crank bolt is factory torqued to about 172+ ft lbs.
You should be able to get it that way with a good 1/2 socket set and and 18" breaker bar. Make sure your turning the right direction...
Old Sep 23, 2007 | 07:37 PM
citymunky's Avatar
Talking
I had the same problem . The answer, let the car turn over two to three times, that is the way I got my off.
Old Sep 23, 2007 | 09:41 PM
App6MT's Avatar
Littering and...
Yeah I just got kinda nervous though. Did you rest the bar directly on the ground and then turn it over? All that seemed to happen was it would raise my car...
I also put the car into 6th gear and then went crazy but no luck. I am definitely willing to do this next weekend though.
Thanks for the advice!
Old Sep 23, 2007 | 11:42 PM
citymunky's Avatar
Talking
I was nervous too. The first two times I tried, I let the car turn over once, each time with NO LUCK. So i hoped back in my car and let it turn over 3 times, and when I checked the bolt was loose. Before all of this I tried the 6th gear and hold the brakes, which did nothing. I also tried what UR said, which was to wedging a crowbar into the drive shaft to lock the crank in place, still nothing.
Old Sep 23, 2007 | 11:51 PM
GreenGoblin's Avatar
The goblin resurrection
i put mine in 6th and had some one jam the breaks and used my 1/2 torque wrench adn some he man strength and it came off
Old Sep 24, 2007 | 08:29 AM
App6MT's Avatar
Littering and...
I really appreciate the responses, it helps a lot! Next weekend I will try CruisnGcoupe's method first and if that doesn't work, then on to citymunky's and then finally Rick's method
Thanks again guys.
Old Oct 6, 2007 | 01:12 PM
slobo7x's Avatar
Put the car in highest gear, 6th, and have someone stand on the brake pedal while you remove the bolt. It works great.
magnetism80
Feb 1, 2019 10:00 AM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
doakley92
Sep 25, 2015 12:58 PM
sullivan72
Sep 22, 2015 11:39 PM
Joe Gargano
Sep 18, 2015 11:17 AM
