Check your plenum bolts if you have a spacer
on
Anyone have a kinetix plenum and have this problem? I am leaning towards the Kinetix for my 05 6MT, instead of a spacer. Now I hear this problem, and it makes me worry as the Kinetix is not even metal. can it flex enough to make the bolts loosen? If a spacer is causing problems, where everything is aluminum, how will a "plastic" plenum cover behave?
Originally Posted by marty315
Anyone have the bolt pattern/order you're to tighten them down in? Can't remember where I stored my instructions when I got the spacer from Tony. Putting in the JDM Battery Cover tomorrow, will check the bolts while I'm at it.
http://motordyneengineering.com/manual.pdf
Originally Posted by GixxerSteve
For the ones that were loose, how long ago did you install your spacer? And how about the ones that were still tight, how long ago for you? I wonder if this is an issue that arises after the spacer has been installed for a longer period of time. ![Dunno](https://g35driver.com/forums/images/smilies/dunno.gif)
#30
