Check your plenum bolts if you have a spacer
Old Sep 30, 2007 | 01:50 PM
  #31
jclayc's Avatar
mine were loose... even the 6 middle ones I used LocTite on. Maybe I'll go get some of the "permanent" LocTite ("Blue"?) instead of just the regular stuff
Old Sep 30, 2007 | 04:05 PM
  #32
Mmagic76's Avatar
Originally Posted by GixxerSteve
For the ones that were loose, how long ago did you install your spacer? And how about the ones that were still tight, how long ago for you? I wonder if this is an issue that arises after the spacer has been installed for a longer period of time.
8 months ago, with a torque wrench too.
Old Sep 30, 2007 | 08:58 PM
  #33
GixxerSteve's Avatar
The Motordyne install instructions tell you to use Blue Loctite, which is the semi-permanent stuff. The Red Loctite is the permanent stuff that requires heat and force to remove.
With all of these issues after 6-8 months, I think I might need to check the bolts on my FX...
Old Oct 1, 2007 | 12:23 PM
  #34
Mmagic76's Avatar
I wonder if the bolts inside the plenum are loose as well?
Old Oct 1, 2007 | 01:48 PM
  #35
jclayc's Avatar
ugh, you're right Mmagic... I'm going to have to check those inside the plenum too..
My kit from Motordyne shipped with LocTite... I used what they shipped. But the bolts I used them on were still loose...
Old Oct 1, 2007 | 02:22 PM
  #36
cato's Avatar
SouthernComfort Moderator
I have tightend mine several time already. Seems that you need to torque them several times a year.
Old Oct 2, 2007 | 09:34 AM
  #37
Mmagic76's Avatar
Forgot to mention that I checked my throttle body bolts as well and they were loose.
Old Oct 2, 2007 | 01:13 PM
  #38
RXM's Avatar
RXM
I'm starting to think that the instruction manual needs to mention in their instructions to make sure bolts are tightened every 3 months or so. I was losing power in my car, so you can guess how loose my bolts were
Old Oct 3, 2007 | 09:04 AM
  #39
Mmagic76's Avatar
Did you check the bolts inside the plenum? I only tightened the ones on the outside... I was going to check the inner ones but it's such a PITA just to get to them!
Old Oct 3, 2007 | 10:49 AM
  #40
RXM's Avatar
RXM
Are you referring to the six bolts that hold down the lower plenum? I didn't retorque those yet...now I'm starting to think I should check.
Old Oct 3, 2007 | 11:49 AM
  #41
Mmagic76's Avatar
Yup, those ones... if you do check them, let me know if they were loose!
Old Oct 3, 2007 | 01:06 PM
  #42
jimmyc13's Avatar
I didn't use any lock-tight and just checked mine...they're all snug & no issues, and I've put about 30K miles on my car since the install.
Old Oct 3, 2007 | 02:36 PM
  #43
RXM's Avatar
RXM
You lie
  #44
RXM's Avatar
RXM
Weekend looks good actually so I probably will open up the car to redo the whole thing.
Old Oct 3, 2007 | 05:11 PM
  #45
jakeup93's Avatar
Same here. I didn't use locktite. I checked my plenum some several months after install and they were all still tight. I don't get annoying whistling or anything, I just notice that on the highway I've got more speed or the car feels like it has longer legs as it will really keep climbing
