Drive by wire
Old Feb 11, 2004 | 04:34 PM
JDMSkyline's Avatar
Drive by wire
just curious is the G35 drive by wire or normal throttle cable??
thanks!
Old Feb 11, 2004 | 05:17 PM
bkchang79's Avatar
Re: Drive by wire
drive by wire
2003 G35 Coupe 6mt Diamond Graphite
1992 Jeep Cherokee Blk 5.5 RE lift /w 33s
AIM= bkchang79
Old Feb 11, 2004 | 06:58 PM
VinNYCG's Avatar
G SQUAD
Re: Drive by wire
Hey can anyone define what drive by wire is? BK your car is off the hook
Old Feb 11, 2004 | 07:49 PM
Anonymous's Avatar
Re: Drive by wire
Drive-by-wire means it's electronically controlled. Theres no actual cable running from the gas-pedal to the engine compartment. The computer adjusts fuel flow according to how you work the gas-pedal.
Anonymous's Avatar
Re: Drive by wire
Old Feb 11, 2004 | 07:52 PM
AirWarrior's Avatar
Re: Drive by wire
I like to refer it as more like "fly by wire". This tech was taken from the military. JSYN
Ace
Old Feb 12, 2004 | 01:07 PM
JDMSkyline's Avatar
Re: Drive by wire
hmmm I wonder why this point is not advertised since it is a pretty advance feature??
Old Feb 12, 2004 | 04:23 PM
derek's Avatar
From: Metropolitan South Farmington, not too far from the supercity we all know as Wilmot, NS
Re: Drive by wire
It is advertised, both on the website and in the brochure. What is more impressive is what it is needed for- VDC. While basic traction control can be achieved without, effective stability control systems need the ability to take the throttle out of your control in milliseconds, so the computer can deal with the mess you've made.
On my second test drive in late Nov 02, the salesman took me to a quite business park on a Sunday morning. As I was setting up for what I assessed as a turn that in my old Corrado I'd have done at 90 (normal method, double the yellow warning sign speed, add 10), I began to touch the brakes to haul down from around 140. He says, "no, just mash it" (I look down to see 120). My wife takes a big breath, I think oh well, plenty of run off, rwd, we're in for a spin. I get ready to counter steer, turn in hard, throttle mashed, and.....nothing. Car goes whisper quite, brakes grab momentarily, and off we shoot the exit, all the while looking like Juan Pablo or Michael. Nope. I can't drive that well. Thank you VDC. Drive by wire, though cool, is just a component, like the accelerometers, abs sensors, and computer.
Fly by wire? check out some of the new concept cars that use a joystick instead of a steering wheel and pedals. Audi starting looking at it 5 years ago, using a pressure sensitive stationary stick a la F-16. That's fly-by-wire.
Cheers,
Derek
DB
Old Feb 12, 2004 | 04:28 PM
myG35ZX's Avatar
Re: Drive by wire
My F350 has it to - 1999 model
G35 Coupe 5AT, DP, Tire and Wheel Pkg., Aluminum Pedals, Clear Corners, missing turbo
Old Feb 12, 2004 | 06:02 PM
ryoken's Avatar
Re: Drive by wire
Just be careful doing that. As good as stability control systems are, they can't exceed the laws of physics. If you're going too fast into the corner and don't have enough rubber, the car's gonna keep going roughly straight no matter what the car's computer tries to do about it.
Old Feb 12, 2004 | 06:16 PM
Profile4's Avatar
Re: Drive by wire
IMO, drive by wire sux, you can see throttle lag (lack of throttle responsiveness)
Old Feb 12, 2004 | 07:42 PM
derek's Avatar
Re: Drive by wire
Ryoken, too true- note my comment ref runoff. Another of my friends wanted to see the limits of the VDC (mechanical engineer and enthusiast) but late last winter, from a standstill, in the snow, I was unable to overwhelm the system. Try as I might, with it engaged, I could not get the car to spin in an empty parking lot (long string of serpentine half moons down the lot). Deselecting the system- car spun in a blink. Then this past fall, in the rain, a different test. Accelerate to around the top of first with some drift on, then throw it hard over (we launched from a t-junction onto an empty four lane street and went to lock with the throttle pinned at the other side, making a left) We succeeded! The system was unable to stop the spin, so it slowed the spin to an almost slow-mo controllable pace, but we did get it to come around 180 degrees. This by the way delighted my friend, since he was afraid to VDC would interfere "too much". The intervention allowed me to control the vehicle, while still not negating the handling of the rwd vehicle. For the most part, the VDC will result in some (normally healthy) understeer.
Profile, doubt your perceiving lag. More likely, it's the system keeping you closer to the limits of traction rather than smoking your Pilots. Hammer on and off around 2 thirds up the rev range in say 3rd (where traction and power are closer to balanced). on warm tires. Engine responds to your foot pretty darn fast IMO.
DB
Old Feb 12, 2004 | 08:57 PM
AirWarrior's Avatar
Re: Drive by wire
If you feel that the drive by wire is a slow response, try some grounding wires. From what i understand, that should help with the response of the engine by grounding out all the extra frequencies.
ace
Hasanbaloch
Feb 29, 2024 08:45 PM
Calvin
Southern California
12
Oct 15, 2015 04:21 PM
whattf
Sep 1, 2015 07:42 PM
Danielek
Aug 11, 2015 09:33 AM
