What motor oil to use for 2007+ G35 sedan?
Old Oct 5, 2007 | 02:15 PM
Virus's Avatar
Even the normal M1 outperforms the Castrol GTX. However, GTX is absolutely the best dino oil available. I use Amsoil 5w-30. I used to use the Amsoil S2K 0w-30 as it's argueably the best oil available, but it just wasn't cost effective against their normal line of oils. VQ engines take quite some time to breakin. The longest OCI I've seen on a VQ is around the 17k mark and that was with Amsoil. I normally do 10k intervals. I am debating on doing Amsoil on the G as oil changes are free for the life of the car. While I love the added protection, it's more cost prohibitive since I get them for free.
Old Oct 5, 2007 | 03:00 PM
PR G35S's Avatar
Originally Posted by UltimateGee27
I go with my usual Mobile 1 synthetic 10w 30, with synthetic filter. Do the change every 3k-4k
+2
William
G35 S
Old Oct 5, 2007 | 03:53 PM
barrister89's Avatar
Originally Posted by BrianV
Here comes the fun debate. Mobile-1 synthetic isn't really synthetic anymore.
I've heard that a couple times now and curious as to the source.
Here's what Mobile says in a faq on it's website:
"Is Mobil 1 with SuperSyn Technology a fully synthetic motor oil?
Yes, it is. To meet the demanding requirements of today's specifications (and our customers' expectations), Mobil 1 with SuperSyn uses high-performance fluids, including polyalphaolefins (PAOs), along with a proprietary system of additives. Each Mobil 1 with SuperSyn viscosity grade uses a unique combination of synthetic fluids and selected additives in order to tailor the viscosity grade to its specific application."
http://www.mobiloil.com/USA-English/...AQs.aspx#FAQs4
I don't know that much about how synthetic is formulated, but it seems that either Mobile isn't telling the truth, the claims that Mobil 1 isn't synthetic are wrong, or there is a debate as to the meaning of "fully synthetic."
I've used Mobil 1 for years in my last 4 cars. I use synth partly because I'm the type who will forget about or put off oil changes because I get busy with work or something else. Running too long on synthetic is a lot better than running cooked dino oil. In my SUV, I changed the oil about every 7k mis and always felt I was playing it safe. I understand being cautious, but dumping synthetic after 4k miles strikes me as a waste. Might as well stick to dino and save $$.
Old Oct 6, 2007 | 04:23 PM
stardust's Avatar
I've never heard of Mobile-1. What is it? What does it do? I've always used MOBIL-1
Old Oct 6, 2007 | 04:41 PM
BrianV's Avatar
I'm too lazy to look up the source, but what happened was Mobil-1 sued Castrol saying their Castrol Syntec product wasn't a true synthetic by Mobil's definition. There was something in it that made it not fully synthetic. Anyways, Mobil-1 lost the lawsuit and decided they were going to do the same because it's cheaper to make. Thus, they now sell the same basic oil as Castrol Syntec, the same oil they sued castrol over having. Mobil did come out with the extended performance which they charge extra for.
Your main choices for true synthetics are:
Royal Purple
Castrol Syntec Euro Formula
Mobil-1 Extended Performance
Amsoil
I'm sure there are more, but just google the castrol mobil lawsuit and you can find your own info.
Old Oct 6, 2007 | 05:07 PM
Virus's Avatar
Royal Purple
Amsoil
You are correct, Mobil 1 is a Group III based synthetic oil. Stay as far away from Royal Purple as possible. It's just plane horrible for passenger car use and UOA's show you can't use it for much more than 3k oil change intervals in a VQ engine. Castrol GTX performs better than Royal Purple.
Old Oct 8, 2007 | 02:18 AM
aozmaxed's Avatar
Originally Posted by max2k1
5W-30 is the recommended viscosity.
Use any premium conventional oil like Castrol/Penzzoil etc and you'll be fine.
Personally. I only switch my cars to synthetic at around 10K miles - I use regular dino oil till that time.
Did you base the extended dino usage up to 10K miles, before switching to synthetic, for proper oil ring seating reason? Has there been any actual tests on the VQ35 about this?
I'll probably stay with Mobil 1 10w30 (warmer SoCal) with 4-5K mile intervals, after break-in period, as I've been happy with perf results on my '00 Maxima SE 5MT (90K now), still going strong even with a few track days thrown in
Old Oct 15, 2007 | 09:49 PM
blnewt's Avatar
I use Pennzoil 5w30 and a Bosch 3300 filter. Not sure how good the Bosch is but it's priced a couple bucks higher than the Fram and looking at the packaging data (if you believe it, lol) it appears to be a more effective filter.
As far as having to remove all 17 bolts for the plastic engine underguard, my 07 Journey has a hinge on the plastic cover that allows complete access to the oil pan and filter by just removing the back four bolts. You have to use something to keep the plastic "hinged", I just used an extra jackstand to keep it pryed open while the oil drained. Much easier than having to unscrew 17 bolts
Hasanbaloch
Feb 29, 2024 08:45 PM
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
ghost_g35
Aug 7, 2015 10:31 AM
laksjd84
Jul 24, 2015 05:12 PM
ClwMike
Jul 23, 2015 12:55 PM
