relays
Old Oct 17, 2007 | 08:02 PM
Xblackg35X's Avatar
relays
who knows what the relays go to that is behind the battery up against the firewall> it only shows where the fuses go.
http://www.trademotion.com/partlocat...oupid=3438&com
if you go there and look at number 7.look near number 1.the 4th relay down. i cant find what it goes to.
Old Oct 17, 2007 | 08:10 PM
Xblackg35X's Avatar
<a href="http://img165.imageshack.us/my.php?image=3845140sn3.gif" target="_blank"><img src="http://img165.imageshack.us/img165/4660/3845140sn3.th.gif" border="0" alt="Free Image Hosting at www.ImageShack.us" /></a>
Old Oct 20, 2007 | 03:59 AM
Xblackg35X's Avatar
found out some how water poured down the wires and got in my utec.it sucks cause ive only used the utec for not even a week
Old Oct 20, 2007 | 09:56 AM
KPierson's Avatar
There is a reason that the OEM uses waterproof seals between the engine compartment and the passenger compartment. Most likely your installer ran the MAP sensor (and possibly boost control solenoid) through the OEM grommet, and then didn't seal it up. This gives water a path to follow. If anything is damaged your installer should be responsible.
Old Oct 20, 2007 | 10:00 AM
KPierson's Avatar
Old Oct 20, 2007 | 08:27 PM
Xblackg35X's Avatar
that ia exactly what happened.. i have to call my installer monday. i appreciate the pic man
G35Rican
Jul 31, 2024 01:37 AM
Learned Hand
Oct 1, 2015 09:02 AM
mattdg35
Sep 14, 2015 11:28 AM
mtlruss
Lighting
Sep 9, 2015 07:44 PM
broke_as_ajoke
Aug 22, 2015 08:27 PM
