engine rebuilt
Old Oct 18, 2007 | 06:36 PM
palung's Avatar
engine rebuilt
My car just flooded 2weeks ago and now the insurance is going to total it I want to buy the car back from the insurance and rebuilt the engine? does anybody know any good shop that can rebuilt the engine in Jacksonville, FL area? Any help will be appericiate it, I can't let go off my car I'm too attach to it
Old Oct 18, 2007 | 07:27 PM
xXHotelCrazyXx's Avatar
Sorry to hear that man, but did you have anything special done to it? If not buy another G! Save yourself the head ache
Old Oct 18, 2007 | 09:56 PM
Curt G's Avatar
Avoid it like the plague. It's not the engine that's a big issue. You could probably change the oil and it would be fine. It's all the wiring in the car and potential rust in the future. If they totalled it, count yourself lucky and use the money to buy another one. Good luck!
Old Oct 18, 2007 | 09:59 PM
MyLilBlkG's Avatar
+1^ the fact that it was flooded, means you will definitely have problems in the future with rust/electrical/and other things.
Old Oct 20, 2007 | 11:15 AM
msburton's Avatar
Was it a fresh water flood or salt water flood, it makes a big difference! How high did the water get? I am guessing that it got pretty high if the motor is bad.
Old Oct 20, 2007 | 12:31 PM
Ionic's Avatar
I've seen fresh watter flooded cars fixed and running like new and reliably for years. If you do keep the car make sure to get everything dried up, you might have to take the carpet out and leave it out for a few days. Then have a tech disassemble all of the connectors that got wet, dry them and lube them or spray them down with WD40. If they are rusted already get a new harness.
If the engine is bad drop in a used one, it will be cheaper and faster and you can probably get the harness from the same car.
About 3 years ago I had my shop in the back of a salvaged car dealer, I remember him saying that flooded cars were some of the best bargains since there was zero body damage and most of them had good engines, you just need to know what to do to get them in proper shape.
Good luck!!
Old Oct 20, 2007 | 05:54 PM
BadBoy06's Avatar
could be worth doing? FL has plenty of nice shops. Check that section out and you'll be surprised
g/l
Freeman186
Sep 6, 2023 10:07 AM
linedr89
Engine - Power Adders
Oct 4, 2015 07:29 PM
Joe Gargano
Sep 18, 2015 11:17 AM
AT23
Sep 15, 2015 07:44 PM
AuAltima3.5
Sep 13, 2015 10:53 AM
