Mixing oil when oil level is low?
Old Oct 21, 2007 | 04:21 PM
Knightt's Avatar
Hi All,
I went out of town with the G and did my regular routine check on the oil and notice it was low (right on L). It has been about 4,000 miles since my last oil change and I plan on getting it soon once I get back home. However, the oil is still clean and I'm not sure what type of oil the Infiniti dealership use (should've asked)...so is it bad for me to add some oil that may not be the same brand? I just want to add some oil so that it doesn't get too low by the time I get back home, or should I be okay?
Old Oct 21, 2007 | 05:01 PM
DrrSeuss's Avatar
manufacturer recommends 5w30 oil..some dealers put in regular, synthetic blend, or just synthetic. Just put in regular oil as soon as possible so you don't do damage to your engine.
Old Oct 21, 2007 | 07:20 PM
zx11pilot's Avatar
No need for the same brand, just try and get the same type of oil i.e 5w30, 10w30. Synthethic oil blends fine with non-synthetic.
You're much better off mixing oils than driving with a low oil level in any case. Once that oil level goes low and you spin a rod bearing, the damage is done. You'd have to get way more than a quart low for that though....
Old Oct 21, 2007 | 07:46 PM
Knightt's Avatar
Thanks!
I figured it wouldn't hurt to mix especially when I expect to have an oil change this week, better than running on low oil...
Old Oct 21, 2007 | 07:48 PM
SILVERSURFERG35's Avatar
Mix all of the time ! You will be ok brother !
Old Oct 21, 2007 | 08:25 PM
Gday's Avatar
If you're low in oil at 4k, then you have another issues besides deciding which oil to use.
Old Oct 21, 2007 | 09:27 PM
Knightt's Avatar
I've never had this problem and the car is 2 years old, I just recently been commuting back and forth from Ohio to Georgia and I figure it was the high heat and all the highway driving I've been doing...I heard about the oil consumption problem but I'll look into it if it keeps occurring..thanks!
Old Oct 21, 2007 | 09:42 PM
V35 Skyline GT's Avatar
6MT Coupe
Just so you know...Nissan/Infiniti wont do anything about it unless you're worse than 1qt/1000mi. Trust me, I know
Old Oct 21, 2007 | 10:48 PM
Knightt's Avatar
Thanks for letting me know...I remember reading all the threads related to the oil consumption and what you and Andy was going through, hopefully it's not my case.
I actually just went to get a quart of Mobil 1 and filled the engine up and it took my oil level to half way. I guess that's not too bad for running 4,710 miles since my last oil change (all highway)...I bought another quart and added it just to make sure and it brought it up to a little bit past full. Probably overdid it but at least that should hold me up till I go home...thanks again everyone!
Old Oct 21, 2007 | 11:31 PM
6MT Coupe
^^^No problem...wish mine were good as yours.
Still...I even find your consumption unacceptable in todays standards and when there's lots of rev-up VQ's that have no consumption issues at all.
Btw, Andy got his replacement. It's all good far as I know.
Have safe travels home...
Old Oct 22, 2007 | 11:38 AM
Knightt's Avatar
Just wanted to update...called Infiniti dealership and they said they use Castrol Synthetic.
Old Oct 22, 2007 | 11:47 AM
Jeff92se's Avatar
Red Card Crew
You can use any brand you like in the viscosity you run ie.. 5w-30.
Old Oct 23, 2007 | 04:07 PM
jin22gt's Avatar
sorry to veer off the topic but is it just me or does our car have a bad dip-stick? its so hard to put it back into the hole... any of you guys know a trick to put the dip-stick into the hole? i always gotta do it couple of times.
Old Oct 23, 2007 | 04:22 PM
kamalster's Avatar
you can't just shove it in there, you'll hurt her. you gotta ease it in...
Old Oct 23, 2007 | 04:30 PM
fortified's Avatar
You can run the right weight with any brand, in a pinch.
I would not do it as a regular thing.
