i NEED HELP WITH A PLUGIN
Old Feb 19, 2004 | 07:04 PM
theskipps's Avatar
I appreciate everyone who has helped to answer all the questions i've asked.If i could impose on you again,i would be very grateful for the help.I have a plugin that i'm trying to figure what it plugs into.It is located on the front of the car ,where the horns are.There are four sets of wires there, two sets of these wires plug into the horns,one plugs into the condenser,and there's another wire there that plugs into something that i can't seem to figure out. I believe you can see these when you open the hood and look behind the grille.Anyway it branches off from the one that plugs in to the condenser.I hope this is clear enough to understand.
Thanks
Old Feb 19, 2004 | 08:24 PM
Meatshackle's Avatar
Deep Sea Moderator
Re: i NEED HELP WITH A PLUGIN
Air bag sensor?
I have a plug directly below the hood latch and the part number says A/B #####
Russ
Black 6MT Coupe
Jax, FL
PS2 and Headrest Monitors Thread
Old Feb 19, 2004 | 10:03 PM
theskipps's Avatar
Thanks for the suggestion,but it's not the air bag sensor .I have that one already plugged in,this one is to the left of the air bag sensor somewhere to the left of the horns,it branches into two plugins,ones goes to the condenser,and the other is the one i need.
Thanks
Old Feb 19, 2004 | 10:21 PM
SFLG35's Avatar
FGC President
why are they unplugged
did you unplug them or were they that way
Daniel
5AT Coupe / DP / Premium / Aero / Clear Bra / 5% Tint - 30% Windshield / Ground Kit / Clear Corners / Shock Sensor / L.E.D. Hood Lights
Old Feb 19, 2004 | 10:28 PM
DaveO's Avatar
Could it be the ambient air temperature sensor?
A picture? How about the number of wires with colors in the missing component group?
DaveO - 2003 G35 Sedan / DP / Willow / AT / Premium / Sport
350Z Engine Cover, T-Stat & Air Duct / Stillen CAI
GG 7-Wire H-G Kit / TS ECU / E-Fans
Street Edge TC / B&M Cooler / Stillen Exhaust
Old Feb 19, 2004 | 10:43 PM
Deep Sea Moderator
I saw the one you're talking about but can't see exactly what it is throught the hole. I think DaveO might be right because it doesn't go to a large componenet, it plugs into something the same size as the air bag sensor.
Russ
Black 6MT Coupe
Jax, FL
Finnkc
Jan 4, 2015 08:35 PM
Dal35
Jun 22, 2014 08:47 AM
hal
Forced Induction
12
Aug 28, 2012 11:57 PM
BIRU
Picture Share
44
Sep 16, 2007 11:53 PM
