DIY for Clear Corners?
Old Feb 20, 2004 | 12:48 PM
DaN_the_MaN's Avatar
Do you guys know where I can find a DIY for the clear corner install?
Thanks.
Twilight Blue G35 Coupe 6MT
Premium - Nav - Aero - Trunk Mat
Injen CAI
Old Feb 20, 2004 | 01:15 PM
wreck's Avatar
Running for his life!!
Re: DIY for Clear Corners?
hmm I don't recall seeing one.. But it's in the manual I think.
Pretty simple, push Corners towards the bumber a 1/4 inch and pull out.
G35C 6MT / AMG E55
Old Feb 20, 2004 | 01:26 PM
pestilence's Avatar
pretty simple install.. ^-
Old Feb 20, 2004 | 01:29 PM
I was more concerned about which bolts to pull out in the wheel well. Didn't want to pull out too many, just the ones I needed. Am I suppose to take the whole fender off, or just pull it back?
Injen CAI
Old Feb 20, 2004 | 01:52 PM
z_with_back_seat's Avatar
From the manual
G35C - 6MT, DG/G, Aero, BSM, Flaps, Stillen Intake, Z tube, Crawford v5, 6 Wire Grounding Kit, Clear Corners, 2nd Battery (Brake) Cover, Sirius, Momo F16 Evo Shifter, 30% 3M Tint & more to go
Old Feb 20, 2004 | 02:26 PM
afr0puff's Avatar
Supa Dupa Moderator
You don't need any tools. Just pull on it from the wheel well corner. Pops out real easily.
http://www.anythingbox.net
Old Feb 20, 2004 | 03:33 PM
RamboRami's Avatar
G35driver.com Moderator
yeah just use your fingers to pop it out, its really easy, i did it by accident once.... haha [img]/w3timages/icons/smile.gif[/img]
G35c-6MT-DG/Willow/HyperGround/BorlaExhaust/350Z-intake
Old Feb 21, 2004 | 12:57 PM
live2ski's Avatar
Dan,
which bulb are you trying to clear out? You refer to pulling bolts from the wheel well which suggests you are trying to clear corner the blinker in the headlight housing. If that is the case then it is a bit more complicated, if it is the sidemarker then as said above it is cake.
If you want the headlight housing out do the following.
1. Jack up the car, not all the way, just enough to get some working room between the top of the tire and the wheel well (removing the tire helps but is not necessary unless you are a contestant on world's strongest man).
2. Just start removing bolts and clips. There are DIY posts on which ones you need to remove and which you don't, but they aren't hard to remove and if you do it right no damage should be done so I just removed them all.
3. Pull away the plastic until you can get your hands through to the headlight housing.
Do the steps in reverse to reassemble.
ALso, it should be noted that making that bulb clear is not really a DIY project, you pretty much have to buy a new housing as otherwise it involves breaking the housing then eposying it back together.
SOrry for the long post, but hope it helps.
Some mistakes are too much fun to only make once.
2004 G35 coupe - 4150K high/fogs - more to come
Old Nov 5, 2004 | 01:51 PM
DeMoNWaReS's Avatar
I am about to do this today, and let me add that the instructions say that you should disconnect your battery. Instructions are in Japanese and my roomate translated it for me.
Old Nov 14, 2004 | 01:52 AM
accordfreak's Avatar
mine pops out when i wash the car.. haha
they could've at least put 1 screw to hold it.....pos..
RIP
1994 accord coupe ex
269whp / 281wtq @ 14psi
now:TB 6mt w/ nav
Old Nov 14, 2004 | 04:59 AM
gdupg35's Avatar
All of these directions are completely unnecessary. NO tools are required at all - what is all of this utter nonsense about jacking up the car, etc?
Simply pull off the existing corner lenses with your hands.
G'duprideR6
Lights
Oct 12, 2015 06:00 PM
bigmike
Sep 17, 2015 01:58 PM
