what does a NISMO thermostat do?
Old Feb 21, 2004 | 02:58 AM
AznIceRckt's Avatar
so, i know it opens at a lower temperature (something like 154 vs 170 stock i think). but... i'm still learning, what does this actually do?
does this mean that the cooling systen of the car is activated when the water temp reaches a lower temp? and if so, does this just mean that the car begins to run its cooling system sooner?
i'm just curious as to the long-term performance gains.,.. or what effects this mod actually does.
-phil
*** 2003 G35s 5a/t / Pearl White ***<P ID="edit"><FONT class="small"><EM>Edited by AznIceRckt on 02/21/04 12:00 AM.</EM></FONT></P>
Old Feb 21, 2004 | 08:37 AM
hotg35's Avatar
Re: what does a NISMO thermostat do?
It helps empty your pocket.
Old Feb 21, 2004 | 08:49 AM
Meatshackle's Avatar
Deep Sea Moderator
I asked the same question a few months ago and couldn't get an answer. I think hotg35 might be right.
Russ
Black 6MT Coupe
Jax, FL
PS2 and Headrest Monitors Thread
Old Feb 22, 2004 | 12:06 PM
G35TR's Avatar
Basically, helps keep the car cooler during hard driving/track situations. More of a reliability upgrade rather then a performance upgrape.
Old Feb 22, 2004 | 05:55 PM
dklau33's Avatar
Right, having a NISMO thermostat for daily driving isn't going to give any benefits. Where it will give benefits is on the track where constant high temperatures are normal due to regular hard driving. Having the lower temperature thermostat will keep the car running at a cooler level. For normal daily driving that might not be so good since there is a nominal engine temp range the car needs to run in for optimal engine life, gas mileage, etc.
04' G35S 6MT Ivory Pearl, Willow, Premium
Old Feb 23, 2004 | 01:33 AM
Buddha's Avatar
its all for show
04 G35C 6mt/aero kit/nav/premium
Old Feb 24, 2004 | 11:30 PM
AirSplat's Avatar
what dklau said was absolutely correct. I had one installed on my previous car. For every day driving my thermometer was usually just below the 1/2 mark. After the upgrade, it runs just around the 1/4 mark. When I drive it harder, it moves back up to the 1/2 mark, but it can sometmies return to the 1/4 when cruising. So, it gives the engine that extra cushion of cooling period. It's a good buy if you have FI. But along with FI comes oil cooler, and higher pressure radiator cap and etc....
'04 G35 6MT Ivory Pearl
K&N Drop In / Stillen Grounding Kit
Borla Headers/Dual Cat-Back Exhaust
Nismo Front Bumper/Side Skirts
Impul Rear Bumper/Spoiler
AirSplat.com for AirSoft Guns!
Picture Share
Feb 4, 2018 12:41 PM
dseet
Oct 11, 2015 12:40 AM
AL8782
Oct 3, 2015 10:26 AM
Jay123
Sep 28, 2015 08:42 PM
