Heater doesn't work while idle
Originally Posted by badtziscool
Just FYI.
My heater blows hot air no matter if I sit idle or if I'm at speed. I'm pretty sure of this because I was sitting in the park n ride waiting for my bus for about 10 min and it was nice and toasty. It was 31F outside.
Here's a question. When you're stationary. Have you tried to bring the revs up to about 1500-2000 rpm while in neutral? I'm not sure if the water pump on our VQ is electrical or mechanical. That should help by eliminating variables.
I had my car up on the lift at work and i'm having the same problem at idle. I've been revving up the engine up to 1500 to 2000 rpm's when at light's. This tell's me that the water pump is mechanical, not electrical. I'm gonna do my thermostat this week some time cause i'm thinkin the nissan t-stat's have a hard to opening up when they get badd. So in return it doesn't open up for the coolant flow to move around the engine.
Originally Posted by HomieG35
Pretty sure. That's the one to check if you have air in the system. May want to try it on different inclines and while pooring some more coolant in.
Having air pockets potentially reach cylinder walls is very, very, very bad.
Well i checked the breather valve on the hose that goes into the heater core and found that it was dry. So i started up the car and put it up in the front with the lift. Still didn't have coolant going into the heater core. Topped off radiator and 1/2 of the expansion tank and anitfreeze started coming out of the breather hole.
Checked heat at idle from cold start up to normal temp. Heat started to work after normally again now.
joedaddy1
Jul 28, 2015 02:58 PM
Rehman2009
Jul 27, 2015 03:23 AM
